![]() Drives: 2007 Yaris Sedan Join Date: Apr 2007
Rattle TSB I found the other day.
I didn't see where this was covered yet. I know some of you guys have complained of a rattle. most common in reverse (on automatics). Well I found a TSB at work the other day for the shift cable rattling. The official fix from toyota is a zip tie
. there is a bracket on the fire wall that the shift cable sits against but isn't attached to. Just zip tie the cable to the bracket, problem solved.
Pic asked
Anyone got a pic of the metal bracket ?
I have the same problem with my 5-speed manual Tsport ! I would like to compare the brackets and see if the tie helps me as good as with the auto transmission. Thanks |
#3 | |
46 and 2, just ahead...
Drives: 07 Yaris sedan Join Date: Jun 2007
I am experiencing exactly the same problem here with my automatic
If you could provide me some pictures that would be great since my dealership could not fix it ![]() I would have to do it my self i guess ![]() Thanks |
Sorry guys just noticed the replies. I'll have to check on a TSB # for ya. I dont have a camera at the moment so I cant help you on a pic. But if you look behind the engine, on the drivers side you should be able to see the shift cable. Right next to it there is a bracket that is wire form. Its not solid, its just made out of thin round stock.
This fix doe's indeed work... I would never have suspected that part but I secured it with a Zip-Tie and the rattle is GONE. Good find ToyotaTEch21...
I recommend doing the fix yourself from under the car. It will take you less time than driving to the dealership. |
![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
Dear all, PLEASE HELP!! What is TSB and how does it look like? Does TSB related to our Auto box cable?
![]() ![]() I'm having the rattle sound too on my auto yaris. But i can't seem to find any auto cable around my firewall. Some mentioned to cable-tie it around the cable and some mentioned to do it under the hood n etc. I'm too confused which is the exact sport to cable-tie it. Pls provide some pictures to enlighten me. Me too want to have a "smooth" when doing reverse with my auto yaris.
T-SB-0336-09
Rattle Noise from Automatic Transmission Control Cable Assembly in Reverse This was updated in September of 09 to include 08 and 09 cars. T-SB-0336-09 Rattle Noise from AT Control Cable in Reverse.pdf |
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Shine a flashlight along the cable to where it passes under the rear of the engine compartment (fire wall). You will see a flimsy wire thingy. That's the bracket you zip tie the cable to. I did it from above without much trouble. If you can get access from below it's probably easier to do. Hope this helps.
Oh yeah i see what you guys mean that stupid braket that seems to do nothing but allow the cable to rest against.
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
mine was black sail panels right above/near side mirrors. by front windows between windshield.
remove from inside fender, do not break...install rubber o-rings. yay. i actually used some foam rings i had laying around for a cadillac door panel. |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
I can confirm the rattle exists in 2010 US Yaris 5 door automatics
I was sitting idle...and heard...umm...a rumble ? or rattle... anyhow....dug up this thread. ziptied my cable to the bracket. now the Yaris is quieter in all situations. seems the rattle adds to overall noise no matter what mode you happen to be in. ziptied....now the little piglet is quieter everywhere. |
#13 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
#14 |
Right beside you, wave
Drives: 08 PBM Yaris Sedan Join Date: Oct 2008
Went in today after seeing this and they have to order the part, but it will be fixed. I take it no one had to pay for theirs. I haven't, but I did forget to ask about it.
![]() 2008 Toyota Yaris Sedan. Pacific Blue Mica. Custom vinyl eyebrows, color matched interior trim pieces, Vios lip spoiler, 17" Maas rims 2010 Scion xB 7.0 Release Series. 1535 of 2000. Murasaki. Stock with TRD springs. |
#15 |
Drives: 07 sedan Join Date: Mar 2010
#16 |
No apparently it was something else. Hopefully a new bracket. I can't speak for other dealerships, but the tech guys at mine are very thorough. It also helps that some of them I went to school with.
#17 |
well, 'any old' ziptie may crack, rot, break, not do the job, cut into the housing
a Toyota spec ziptie will just plain work. the difference between walmart zipties and a good one can be huge |
#18 | |
![]() I do have some ties that are designed for use in hot conditions and are UV rated. Might as well use one of those. |
| finally found the 5w-20 TSB... | static808 | DIY / Maintenance / Service | 97 | 01-02-2013 06:28 AM |
| Toronto Canada meet June 16th second part of the day photos | Ric n Sov's Vitz RS | Photo-Video-Media Gallery | 23 | 06-20-2007 01:22 PM |
| TSB for steering pull? | vst | DIY / Maintenance / Service | 12 | 06-09-2007 02:40 PM |
| My New Yaris (First Car), About me, and my TSB Questions | dlinkwit27 | DIY / Maintenance / Service | 1 | 06-03-2007 12:34 PM |
| Rattle fixed! | Bretsuaz | DIY / Maintenance / Service | 32 | 03-30-2007 08:39 PM |
