Old 06-11-2018, 02:00 PM   #1
Awilson089
Drives: Toyota Yaris 2002 Petrol
Exhaust Disconnected from Corrosion
Hi,
I've got an old 1 litre 2002 Toyota Yaris and it looks as if the exhaust has completely disconnected from the muffler.
You can see a quick video here: https://youtu.be/28kaJ2RDrx8
The car seems to run ok but is incredibly loud.
Is there any way i can fix this myself? or will it need a new exhaust?
Cheers
Adam
Awilson089 is offline   Reply With Quote
Old 06-11-2018, 06:55 PM   #2
zoidberg444
zoidberg444's Avatar
Chances are even if you had a welder that its so corroded you wouldn't have much to weld too and there are other places which are pretty bad. You need a new exhaust mate.
UK to Nordkapp in a Yaris
Old 06-11-2018, 07:07 PM   #3
ex-x-fire
Is that the factory exhaust? They are made from better material then the run of the mill replacement exhaust. Find a muffler shop, they can cut that out and weld in a union. We do that all the time at work.
If you need to do it on the cheap, get a hack saw, cut off the flange and find a pipe that slips over the exhaust, then clamp it.
Exhaust manifold damaged by corrosion donpalino DIY / Maintenance / Service 5 05-26-2015 04:38 PM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 05:01 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
