Old 07-03-2018, 05:00 AM   #1
Yaris709
Drives: 07 yaris
Issues with starting sometimes
Having some problems once in a while with my car not starting properly. It will seem as if the starter is sticking and hard for the car to start and runs rough for 4-5 seconds after started, but then runs perfect afterwards. Happens every couple of days. Is this a starter issue or do I look elsewhere?
Yaris709 is offline   Reply With Quote
Old 07-04-2018, 07:21 AM   #2
ex-x-fire
I guess I'd have someone start it while you can listen closely to the starter to see if it is acting up.
Is the check engine light on?
Old 07-06-2018, 06:35 PM   #3
Yaris709
Drives: 07 yaris
Nope no check engine light. Seems as the starter is only partly engaging and keeps cranking for a bit on it's own after. Now next question is how hard is the starter to get at?
Old 07-07-2018, 01:11 PM   #4
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
under the intake manifold. Quite a PITA to replace.
Fluxtasy is offline   Reply With Quote
Old 07-07-2018, 01:41 PM   #5
tmontague
tmontague's Avatar
if you remove the lower engine dust covers it isn't too hard to remove the starter. Access the bolts from the top and bottom, there is only two, and obviously remove the electrical connectors and that is it. Not the simplest but if you've worked on your car before it won't be a surprise
Old 07-08-2018, 02:02 PM   #6
Yaris709
Drives: 07 yaris
Sized it up and looks like a straightforward but PITA to do haha now the next question is that I went to get a starter today and there is apparently 2 different starters for the yaris? One with climate control and the other without? My car has ac but I don't think that's what they're referring to as climate control. Any help there?
Old 07-08-2018, 02:52 PM   #7
tmontague
tmontague's Avatar
one is likely higher amperage for cold climates (known as the winter package). They should have specs on amperage for the two different ones. Go with the one with higher amperage
Old 07-09-2018, 01:52 AM   #8
Fluxtasy
feed my pet
Fluxtasy's Avatar
Ocassionally my starter sounds rough when I crank. I’m holding off replacement till it gets worse due to that location.
Old 07-09-2018, 07:14 AM   #9
ex-x-fire
You might end up changing the flywheel too.
Yaris intermittent starting problem sujay68@gmail.com General Yaris / Vitz Discussion 0 12-08-2017 08:10 AM
Steering Wheel Jams, Battery Warning Light flickers, Starting Issues tmrtza In Car Entertainment + Electronics (audio / video / alarm) 3 10-31-2014 09:01 PM
07 Starting Issues alfabob DIY / Maintenance / Service 4 02-21-2012 08:01 PM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
