Old 08-29-2018, 03:40 PM   #1
Wbporkypig
Drives: 09 Toyota yaris
Throttle issues
Ok so I got an 09 yaris with some throttle issue. The car runs fine while idle and revs fine to till I start to move. When I try driving it will go but has trouble accelerating, check engine light flashes when I get up to speed. Any ideas
Wbporkypig is offline   Reply With Quote
Old 08-29-2018, 03:45 PM   #2
Get it checked for stored codes. Without doing so, all you'll be getting is guessing game advice.
Old 08-29-2018, 03:49 PM   #3
Wbporkypig
I did that and it told me cylinder 3 and 4 were misfiring, I've already replaced spark plugs. Car ran a lil smoother but the check engine light still there and acceleration problems still there. I will have my friend come over later to check the light again.
Sent from my SM-T350 using Tapatalk
Old 08-29-2018, 03:50 PM   #4
Fault coil packs. Spark plugs are not usually the cause of misfires. Coils are.
Old 08-29-2018, 03:53 PM   #5
Wbporkypig
Ok after I hook computer up to it if it still says misfire I'll replace the coils
Old 08-29-2018, 03:57 PM   #6
You can verify by changing the position of the coils. Swap cylinders 1 and 2 for 3 and 4. If the coils are faulty the codes will follow the bad ones.
Old 08-29-2018, 03:57 PM   #7
Wbporkypig
Ok thanks I'll let ya know wut happens lol
Old 09-03-2018, 12:01 PM   #8
Wbporkypig
Ok so I hooked up to the computer and got p0300, p0301, p0302, p0303, p0304, and p0172. I know what they all mean any easy fix. All cylinders misfire and random misfire and it's running rich
Old 09-04-2018, 09:12 AM   #9
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
what are your fuel trims reading?
Old 09-04-2018, 03:05 PM   #10
Did you clear the codes before swapping the coils around?
Old 09-06-2018, 06:15 PM   #11
Wbporkypig
Idk about fuel trim and I did not swap cause now it's saying misfire on all 4 cylinders
Old 09-06-2018, 06:16 PM   #12
Wbporkypig
Should I still try swapping
Successful 1ZZ Throttle Body Swap rabbito Performance Modifications 34 10-15-2024 08:12 AM
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 01:12 PM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 05:36 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 01:03 PM
