![]() ![]() Drives: 07 yaris Join Date: Dec 2016
Changed starter and still starting issues
Hey guys had some problems with what i thought was my starter sticking so I replaced it and still having the same issue as before. Once in awhile it cranks over longer and hard to get going. Also runs rough for 3 or 4 seconds after starting. Could this be a fuel issue? No idea where to even begin looking now. And no check engine light.
#2 | |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
Battery seems perfect lots of cranking power! Could it possibly be a bad ground or is there more to it than that?
Clean the MAF sensor.
I keep it cleaned regularly, usually every 5k when I change my oil. Completely stumped on this problem
feed my pet
Yup same with my car. I may try the spark plugs as there is 300k on the car and am unsure if they've ever been changed
#8 | |
![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
Spark plugs have to change at least every 70.000. And that’s also a high number. Try to replace those first and if the problem continues then check your fuel pump. It may became weak over the years. But if you have so old spark plugs, then you may have missfires too Sent from my iPhone using Tapatalk |
#9 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
https://www.toyota.com/t3Portal/docu...MS-08Yaris.pdf |
