Old 10-07-2018, 09:27 AM   #1
CB900F2
Drives: 08 Sedan
Radiator Hoses - Gates - Molded
Hi All...
Planning to change the coolant on my 08 Sedan and since the car has 210,000km, I am going to change out the main radiation hoses(2 x upper, and 1 x lower)...
Has anyone tried the Gates hoses? and how well molded are they to the OEM shape?
Thanks!
Old 10-07-2018, 11:04 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by CB900F2 View Post
Hi All...
Thanks!
I've used Gates on numerous vehicles. Can't ever recall an issue.
Old 10-07-2018, 04:16 PM   #3
komichal
Is there a particular reason to change hoses after some mileage? As long as they are not leaking, not cracked and not extremely soft or hard, I would be quite satisfied with keeping them as they are.
Old 10-07-2018, 04:21 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
Provided it's 10years old, it's more about preventive maintenance. It would suck to redo this if it starts leaking months after coolant change. And it's bad for the environment as well, so might as well just replace the hoses while the system is empty anyway.
Sent from my VTR-L09 using Tapatalk
Old 10-08-2018, 04:15 AM   #5
scylla
Drives: 2015 Yaris L
"Provided it's 10years old"
I always change all my main hoses during every flush. Usually every 3 or 4 years. The Yaris' hoses are so inexpensive it's a no brainer.
This winter I will throw a set of hoses in a cart at rockauto and wait for a good coupon. Will be ready for next summer.
scylla is offline   Reply With Quote
Old 10-08-2018, 10:18 AM   #6
CB900F2
Drives: 08 Sedan
Just what IllusionX said..
The hoses appear ok.. just a PM ..
Old 10-10-2018, 12:34 AM   #7
bairjo
Be sure to use the Toyota super duper red coolant....it is supposed be less harmful to to the rubber.
bairjo is offline   Reply With Quote
