Old 11-30-2021, 01:08 PM   #1
Pinchlite
Drives: 2007 yaris HB
Odd sound from engine starts @8-10sec(Cold only)
Only when cold winter.,,once warm it is normal.
The sound starts 8-10 secs in...kind of a howling sound is best to describe.
Seems to be coming from alternator water pump area.
Alt and starter are new btw...I am thinking waterpump..although it is not leaking or splattering coolant.
I do have a new pump already just incase.
https://drive.google.com/file/d/1JnO...YwTvwxRbW/view
You may need earphones?
Pinchlite is offline   Reply With Quote
Old 12-01-2021, 08:17 AM   #2
ex-x-fire
Take the driver belt off and run it when cold. Feel the pulleys for looseness or roughness. Kinda sounds exhaust related.,
Old 12-08-2021, 01:32 PM   #3
Rich_UK
Drives: Yaris mk1 & Yaris mk2
water pump bearing, but its hard to hear when not in person, as already mentioned pull the belt and see if the noise goes then feel the pulleys for play.
Pitty you're not in the UK I got 2 water pumps in the shed as I ordered one about a month ago and didnt arrive the shop sent a second and then they both arrived, saddly wasn't even the water pump leaking so after all that the shop just said just keep them...
Rich_UK is offline   Reply With Quote
Old 01-03-2022, 09:29 AM   #4
Pinchlite
I have a new pump for about a year know.
Thanks though....I updated the sound file....noise more noticable know that its colder -6
P.S the pump does not leak.
Old 01-11-2022, 04:36 PM   #5
CrimsonEclipse
Drives: .
I'm having the same problem, but only a few seconds.
It's either the A/C compressor (which is clutchless I think), the alternator, or the water pump.
I actually have a spare shorter belt specifically in case the compressor locks up
CrimsonEclipse is offline   Reply With Quote
Old 01-11-2022, 04:45 PM   #6
Pinchlite
Well the alt is new..and the ac comp is non functional.even if it worked I would not use anyway.I dont like AC.
I was thinking of removing comp....so I need a shorter belt I assume?
I will be replacing water pump this summer anyhow as i already have new one.
Old 01-13-2022, 12:54 AM   #7
CrimsonEclipse
Drives: .
Yep. It's shorter and you don't need to mod anything. Just loop it on and skip the compressor.
I'll see if I can find the part number.
The parts store can probably find it faster
Old 01-13-2022, 08:43 AM   #8
Pinchlite
Thanks bud!
Old 01-22-2022, 08:43 AM   #9
CrimsonEclipse
Drives: .
I purchased 4PK918
I rechecked and kept coming up with 4PK920
Granted, the difference is only 2mm of total length but you might want to triple check just to be safe
Old 01-22-2022, 08:45 AM   #10
Pinchlite
Thanks buddy!
P.S Do you notice any difference/s without having the condenser?
Old 01-23-2022, 05:11 AM   #11
CrimsonEclipse
Drives: .
Haven't swapped it out yet.
Very strange squish sound!!! Djruel DIY / Maintenance / Service 1 07-13-2016 06:09 AM
Humming Sound on Transmission Uno DIY / Maintenance / Service 0 01-29-2016 07:54 AM
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 06:35 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-05-2011 12:56 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 04:11 AM
