Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I'm going to post my next few transmission videos in this thread for everyone that wants to fix their own gearbox.
Here is the first one, disassembly. https://youtu.be/rL7Od4bM_Rk |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Nice one dude. All very interesting. I've watched a few videos by Paul Cangeolosi who does gearbox rebuilds and it still makes me nervous the thought of trying to get them back together afterwards. haha
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#3 | |
Data doesn't lie
Luckily for my I do this for a living and know my way around pretty easily by now. Any suggestions for the next one focused on the input shaft? |
Data doesn't lie
Here is Part 2 where I disassemble the input shaft!https://youtu.be/OtDJyIkBsXs
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
Insanely fascinating! I always wondered how transmission specialists remember exactly where every tiny component goes. I can see why it can cost thousands to rebuild a transmission. I've heard stories of rebuilt transmissions failing shortly after the rebuild for one reason or another. In your experience, how often does a rebuilt transmission fail shortly after being rebuilt? Is it because of the components used during the rebuild process?
Thanks for these amazing videos and keep posting! I'm sure I'm not the only one that can watch these videos all day. |
2ZR swap. DO IT! Ask how!
Mine is going on 5 years, no issues to report. As long as you're following the repair manual, there's not a lot that will go wrong.
Data doesn't lie
Most of the time I see a transmission fail is due to lack of quality control. Take all of the measurements, clean it thoroughly, use a assembly line, and assemble correctly. Check your work after every step, and if something doesn’t feel right....don’t ignore it.
Failure is almost never due to a defective part, but lands on each persons workmanship |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
I don't doubt one day I'll venture into the transmission internals.. lol -- Adam |
Data doesn't lie
Here is part 3, instructions on how to disassemble the output shaft!https://youtu.be/t9ovNfHYtMw
Nice one dude.
Data doesn't lie
Data doesn't lie
Thanks man, I hope all of this information helps the Toyota fam.
Here is Part 4! Synchronizers! https://youtu.be/kScLPMGAtUM |
So when we 2zz swap my Mrs you'll do the c60?
Data doesn't lie
Of course! But you know it will be easier to do the 6-speed first, gotta make room for it.
Here is Part 5! All of the needed parts to do the LSD install, plus preparing for WPC treatment! https://youtu.be/BRpJZk4onBU |
Data doesn't lie
Here is part 6, case preparations for assembly https://youtu.be/8np3znu1664
Data doesn't lie
LSD install and how to set differential preload video is live!
https://youtu.be/Z4Yk_ek3JrI |
Data doesn't lie
Our video on getting gears WPC Treated is up, this one surprised me!
http://https://youtu.be/-crA5BY4ZjQ |
| Tags |
| gearbox, rebuild, transmission |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
