Old 12-24-2018, 11:39 AM   #1
omarmsabbah
Drives: Toyota Yaris Sedan 2008
Exclamation Coolant Draining, Yaris sedan 2008
i have a yaris 2008 sedan i owned it since brand new it started draining coolant lately but slowly there is no coolant on the ground where i leave it so there is no leak and the car doesn't heat up at all
but i noticed something weird started to happen lately where the fan started going on way more often than usual
the car have never done any repairs or service on the engine since i got it apart from spark plugs and the belt "which were about 3 years ago" that's all
any idea why could this be happening
thank you in advance :D
omarmsabbah is offline   Reply With Quote
Old 12-24-2018, 12:16 PM   #2
tmontague
tmontague's Avatar
Refill coolant and go from there. Seems like its low on coolant either through evaporation as the system is not a closed system or through a leak somewhere
Old 12-24-2018, 12:20 PM   #3
omarmsabbah
Thank you
it did vaporize completely till the car actually became hot and i refilled it but it seems to be doing it again that's why it raises a huge flag this time
note:i didnt drive while it was hot i made sure it cooled off again and bought more coolant and filled it up again what lead to this is me not checking on coolant for a long time :( my bad
Old 12-24-2018, 12:52 PM   #4
dogsridewith
Drives: 2007 2-door hatchback
Yaris overheat
Originally Posted by omarmsabbah View Post
Thank you
"vaporize completely"
From the overflow tank?
From the radiator?
From the engine block/head?
Old 12-24-2018, 12:58 PM   #5
omarmsabbah
From the radiator?
the overflow tank was empty and the car started heating and bulb in the dashboard lit up
the car doesn't have a cap for the radiator so i don't know if it was also from the radiator and the engine block i don't know how to check that but the car heated the light in the dashboard lit up and i had to stop right away and went to buy more coolant to put in the overflow tank of course after waiting for the car to cool off for about 45min
so basically i saw no water in the overflow tank
Old 12-24-2018, 01:02 PM   #6
Where the hell is your rad cap?!?!
Old 12-24-2018, 01:24 PM   #7
omarmsabbah
Unhappy it has none
its on a hose (the upper coolant hose to be exact) where it shows nothing inside the radiator it self i have the cap on the hose and the tap on the overflow tank that's all
just like the picture below :/
Old 12-24-2018, 02:24 PM   #8
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
dont fill your radiator with tap water while its hot. dont put coolant in an overheating engine.
DarkShadowFox is offline   Reply With Quote
Old 12-24-2018, 05:16 PM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
Lol that's still your rad cap.
If you just filled while it was cool, you gonna need to run it until the thermostat opens up and flows water through to let all the bubbles out.
Old 12-24-2018, 06:06 PM   #10
dogsridewith
The overflow tank will only fill the radiator a little bit each time the engine cools down (overnight)...then when the engine heats up, the radiator pushes a little bit back into the overflow tank. (That's how it works if everything is up to level) So you can see that the overflow tank cap is no way to fill a low or empty radiator.
That engine may have a blown headgasket and warped head.
What were the circumstances around the belt and waterpump replacement?
Tags
coolant, drain, problem, sedan, yaris 2008
For Sale Feeler: Long Island, NY - 2008 Red Yaris Sedan .... tdinut Cars for Sale by private party 0 08-02-2015 12:41 AM
Replace 2008 Yaris D4 sedan passenger side window harvey DIY / Maintenance / Service 0 08-01-2015 02:53 PM
YARIS SEDAN 2008 basharalezze Third Gen Yaris General Discussion 2 01-22-2015 06:46 AM
