The dangers of overfilling your gas tank
I often continue to fill my tank after the first click… just to round off the number. This article gives me pause for thought.
https://www.msn.com/en-us/autos/owne...cid=spartanntp |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
i don't know if i would really classify those as "dangers."
i usually round to the nearest 10th cent. i'm not scared... |
I got a chuckle out of that.I remember hearing something a long time ago about it not being good for the car to fill past the first click, so that's what I've done with my Yaris. Before it, I would "top off" my tanks. At the end of the day, I don't think the added drops are worth any risk, so I'd play it safe rather than sorry. Stopping for gas a couple miles early just isn't worth it, imho. |
#4 | |
I put 1-2L of fuel easily after the first click and it's not nearly reaching the tube.
Sent from my CLT-L04 using Tapatalk |
![]() ![]() ![]() Drives: 2009 5-Door Liftback Join Date: Jun 2011
I typically stop filling after I hear a second click. No problems yet, but I'll consider stopping after the first click from now on.
Toyota Yaris fuel tank fill shut off click EVAP system charcoal canister codes
If it isn't an errant half-fill click off, something happened--some tank pressure increase--at the first click shut off. Manual says to stop there. Why go against manual recommendation? There's a complicated EVAP system that wants vapor space in the top of the tank.
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
In my case, my evap system is already on vacation.... Fill er up!
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
I’m a one click kind a guy and have been all my driving life!
I'm pretty sure I fuel-logged - and as a result destroyed - my evap canister on my older Dodge Grand Caravan due to repeated overfilling. I now always stop at the click. I think I saw somewhere that a charcoal canister for the Yaris is north of $600.00 USD. Yikes!
$600? Whoa, I'm definitely stopping after the first click from now on!
I did find one for my 2008. The OEM is actually about $500.00 CAD. But, from a local dealer??? Not cheap!
#14 |
And that's for the part alone, not labor. I'm no mechanic, so I would have to pay for labor on top of the part cost. And that would definitely not be cheap! I'm glad this thread was started. I will definitely stop topping off. No damage has happened thus far. But it's clearly a silly gamble with no real benefit.
| WTB: GAS TANK, FUEL PUMP, EVAP HOSE, CANISTER | Wisher23 | Willing to Buy by private party | 1 | 02-20-2024 06:46 PM |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 07:41 PM |
| DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) | CTScott | DIY / Maintenance / Service | 1 | 08-21-2013 04:57 PM |
| Natural Gas Transportation - Why Not? | Kal-El | Off-topic / Other Cars / Everything else Discussions | 1 | 03-20-2011 02:12 PM |
| Full Gas Tank Noise? | hoahmaru | General Yaris / Vitz Discussion | 8 | 04-10-2006 01:17 AM |
