In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
gas gauge and wiper jet spray
most two problems: with all this cold weather as anyone else had the problem than when the last bar is flashing you fill up completely and the fuel gauge doesn't correct itself?
Today I drove to work which is about and hour with traffic and it stayed flashing. Only on the way homei hit a bump and it finally corrected itself. it been the third time so far. But when it does that does the computer know that the car is full or not? for the wiper jet spray got it replaced with the tsb but it just as bad! Does anyone know if there is an after market one i can get like the old version where you can control yourself where the spray is going? thanks |
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
spray nozzle: try putting something under the nozzle so as to change the spray orientation. it worked for me. don't try to modify the nozzle outlet - this didn't work for me = 25$ a new one
![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
If you mean the one that you can change the direction of the spray with a needle, then you may purchase one for a toyota echo
20 years... alive and kickin'!! ![]()
Get some LED jets... your car will look like it has a lazy eye. The sprayers are off kilter.
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
kinda funny i got white nipple lights that im going to wire to my blinkers and a switch to override and be always on or off... i noticed there not centered but w/e if i dont like it ill take the LED's out and leave the chrome washer nozzle lol
"It hurts more when its wet" |
