Old 02-13-2020, 12:05 AM   #1
mannycheckers
Drives: 2009 Yaris 2dr Liftback
Steering Squeeking
Greetings,
I have a 2009 Yaris Liftback (42,000 miles) that has a strange squeal/squeek when turning the steering wheel left. The issue occurs when the vehicle is stationary and turning at low speeds. The issue does not occur when turning right.
I have recently installed TRD springs/shocks, new wheels, tires, and got an alignment. The problem may have been present before these changes were made, but I am not sure. The noise started out really faint and is progressively getting louder.
Here is a link to the symptom:
https://imgur.com/a/LUatpAE
I am unsure of the cause. According to the 2007 service manual, the problem may be the electronic power steering motor, but I hope not.
Does anyone have any ideas of the cause?
Thanks.
mannycheckers is offline   Reply With Quote
Old 02-13-2020, 03:07 PM   #2
remcafee
Take a bottle of silicone spray, start spraying all the suspension components and see if that helps, like the control arm bushing, shock mounts, boots, steering knuckle and all of it
No power steering on '08 Yaris after airbag recall done madradjessica DIY / Maintenance / Service 14 12-18-2018 09:14 PM
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 01:19 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
Steering wander, adjusting EPS assist Snubba Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-22-2012 06:39 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
