![]() Drives: yaris d4d 2013 Join Date: Sep 2019
Power cable pass through
Hello i 'm new here, by the chance, I'm George and i have a 2013 d4d yaris. I want to install an amp and a sub and i wonder if there is a cable pass through from engine bay to cabin. A gromet or something i can't find it, in almost all cars is next to pedals i try to find it but there is nothing. Anyone that has done it? Thank you for your time.
P.S. sorry if my English are not so good |
![]() Drives: 2007 Yaris LB Join Date: Aug 2009
Yeah I had this issue, but it was on a 2007. Wayyy harder to find than any other car I've worked on.
I ended up putting my head in the gas pedal area, and reaching way up to find a rubber boot above the steering column. It's pretty thick. I poked a hole in there, fed a stiff wire through, then attached the thick wire and pulled it through (which I lost several times, and ended up having to tape it lengthwise quite longly)
Keith, 2007 Yaris Liftback YouTube: Keith's Test Garage | http://www.KeithsTestGarage.com |
![]() Drives: RS Join Date: Apr 2010
After removing the plastic inner wheel well. Try drilling through the wheel well. Then carry the power wire through the hole you drilled out of the firewall, to the battery.
I'll post photos of what I did later... |
![]() Drives: 2008 black Join Date: May 2014
On the 2008 there is a grommet on passenger side, i believe just above or beside the computer on firewall side. Punch hole through then leave the tool used in it or put something else in there. Go inside car on pax side and remove glove box and you may see it but you might need to pull the carpet back from top left. It is difficult but it is there and it is not used. Careful when trying to make the hole as you might push the whole grommet in if so you can find it on the other side but still leave the tool used to punch it out in hole as easier to locate on the other side.
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
May depend on right hand drive or left?
On left hand drive (usa) I did the same as Winter.
| Power lock questions | Taiyaki | DIY / Maintenance / Service | 22 | 04-22-2009 10:22 PM |
| Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) | gaffo | General Yaris / Vitz Discussion | 28 | 07-15-2007 07:55 PM |
