![]() Drives: 2007 Yaris Sedan 4 Door Join Date: Jun 2007
due to all the salt they use here in the winter it went bye bye, no way to reattach. what are the risks? I see the pipe to one side of the tank, hmmm, tank looks plastic, just don't know how much heat comes from that small pipe, especially to the side? looks like maybe 4 or 5 inches from pipe to tank in that area
I am not sure how critical it is, or if it is there primarily in the event that the exhaust leaks. The list is about $80 for the two pieces, which seems a bit expensive.
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
The gas tank heat shield is REQUIRED. Our gas tank is made of plastic and without the shield you run the risk of it melting.
I was told this the last time a piece of my shield fell off (which actually does make sense and didn't seem like dealer speak for $$). |
#4 | |
...our manifold is plastic.....BUT, there is always a risk, right
![]() Quote:
if theyre the same for the sedan, i have yaris heat sheilds on the scrapper hatchback in my driveway
^ Oooo...
Gotta check mine. Last time I was under there, it looked like one of the mounting points was just about eaten through.
Drives: Yaris Sedan Join Date: Feb 2015
My heat shield was dragging on the ground. It was hanging by one bolt, so I took it off and brought my car to the dealership.
They looked at it and the technician said that I didn't need it, but if I wanted to get it replaced, parts and labor would cost $189. I chose not to replace it. If my car catches on fire and I survive, I'll come back and let everyone know. |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
I removed the heat shield because it started to rattle on idle. The gas tank is never going to melt unless the exhaust pipe is literally touching the tank.
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
I would say the only danger you'll run into (other than risk of external damage) is potentially over pressurizing the fuel tank, especially since gasoline is such a volatile mixture. Even so, all gas tanks have pressure relieving devices designed specifically to avoid situations like these, so you should be fine.
On the plus side, you're warming up your fuel so you might get better fuel economy because of liquid expansion?
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
Mr. 155 and climbing
I have not had my heat shields since 2009. They were ripped off by the other half not noticing a cinder block and backing over it. peeled out the shields like tearing paper. With what I do with the car and not blowing up yet or having any melting occur I would think that you are fine at least for a little while. I have also removed my fuel tank a half dozen times and every time that I do I inspect it.
Would you put your hand as close as your exhaust is to the gas tank? If it's 5 inches and guaranteed I won't slip, yes, I would. Heck, I'd put my hand within an inch of the exhaust even while it's running. It's too hot to touch, but not too hot to be nearby, otherwise your bumper would melt.
My hand feels pain well before plastic melts, so it's up to you, but I wouldn't (and don't... one already fell off) worry about it. |
![]() Drives: Yaris 2007 3 doors Join Date: Jul 2009
same here , 3 attaching points now have a big washer at each location to grab
the thin sheet and hold it , now I have a rattle that sounds exactly as the shield does , but it is not the shield ??? removed rear drums , lip on back plates is rusty and touching the drum , I pulled away the rusty parts , still have the mysterious rattle , mostly when first taking off , never does it at speeds ... |
![]() ![]() Drives: 2007 Yaris sedan Join Date: Nov 2011
mine fell off probably 30000 miles ago..... never replaced it... no issues so far at 190000.
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Natural Gas Transportation - Why Not? | Kal-El | Off-topic / Other Cars / Everything else Discussions | 1 | 03-20-2011 01:12 PM |
| part of heat shield fell off | jeff69dini | DIY / Maintenance / Service | 4 | 03-17-2011 05:42 PM |
| Filling up using spare gas tank. | Yarimoto | Fuel Economy Forum | 5 | 08-19-2009 04:29 PM |
| General Warning and Fuel Tank Heat Shield | ttufrosty | General Yaris / Vitz Discussion | 8 | 05-31-2007 10:59 PM |
