![]() Drives: echo turbo Join Date: Apr 2019
AWD/4WD convert my Yaris turbo
Hello! help needed, has it been done before? Ive seen the 3sgte with the celica gt four gearbox but thats a engine swap. maybe an easier way?
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
You have been watching too much project Binky dude.
I have heard rumours that there is a Yaris derivative model in Japan (possibly the Belta?) which is basically an AWD Yaris. I think there is this niche in the Japanese market for "snow cars" which are used up in the high altitude areas in the winter. You could look into if you could import one. Mighty Car Mods had a project where they did an AWD conversion on a Daihatsu Mira by using a wrecked Japanese AWD Mira and using the parts from a half cut and putting it into an Australian road legal Mira. In that case they actually swapped the floor pan between cars by removing all the spot welds and welding the AWD floor pan in and swapping over the rear diff, engine, gearbox, drive shaft and the wiring looms and ECU's. It was a huge job.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
![]() ![]() Drives: Yaris Join Date: Feb 2019
The Vitz did come in a 1.3 4x4, Good luck finding a GT4
http://www.yarisworld.com/forums/showthread.php?t=57031 There are too many project on youtube that make things look simple, unless you have buckets of money, equipped workshop and the technical skills you're dreaming https://www.youtube.com/channel/UCL3...JNu0ACp9olaMUA |
#4 | |||
2ZR swap. DO IT! Ask how!
There are serious hurdles to overcome though: * The AWD version is only available in automatic. The transfer case is integral to the transmission and would require a custom housing to mate to a manual gearbox. * The JDM versions are all right hand drive. The firewall is almost certainly specific to RHD and will have to be replaced (the way MCM did with the floor pan) to get LHD. * The driveline is designed for a 1.3L engine. Putting 200+hp through it will likely exceed the design intent and end catastrophically. Don't get me wrong, if you have the time, money, skills and resources to make it happen, go for it! We would love to see it happen and there are lots of people can help you figure out the details. |
3 Yaris and counting..
Simple solution.
Get a jeep. Pull the body from the frame. Lower yaris body onto the jeep frame with entire driveline present. When something hits, cut it out. Continue lowering and cutting until body sits on frame where you want. Start welding!
#6 | |
I'll do it one day! Hahaha
Believe it or Not, the wheel base is similar in length. Eyed it out parked next to my buddies girl's jeep lol
| Tags |
| awd 4wd |
| 2ZR Turbo Yaris | 06YarisRS | Forced Induction Forum | 562 | 08-28-2025 03:49 AM |
| Yaris turbo kit | RF-EDITION | Forced Induction Forum | 3 | 05-19-2013 12:37 PM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-10-2012 12:35 AM |
