Old 03-09-2020, 04:19 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
steering mods
This is about a 99 sienna Van but its a Toyota and I have a Yaris....640K miles truly.Original all including clutch. But it shudders a little bit..
If I ask about mods on most sites the establishment jack asses always get scared and say dont do mods...stick to stock...they make me sick.Yaris people tend to have guts or they wouldnt have bought a tiny Yaris anyway.
The power steering H pump on the Sienna needs replace. I really would like to change it back to a simpler set up. Pull out the hydraulic ram and just go bck to rack and pinion
with a old style steering box. The hydraulic set up on Siennas is known for failing.
I dont know if those steering boxes have power or not. I know they have oil of some kind.
Has anyone here done any mods on their steering systems???? Can you get a 12v powered steering box that would help turn an offset knuckle like you find on Rack and Pinion.??? I dont know if we have many mechanics on the forum...I hope there are some..
yaris9876 is offline   Reply With Quote
Old 03-10-2020, 11:03 AM   #2
Brighton
Knower of little
Drives: None
The toyota electric steering systems are oil-less I believe and Toyota likes to keep things modular so you could probably find a complete hydraulic system from an older SUV/Truck in the junkyard. I'd stick with pulling it from a 4Runner, Pickup or Previa? You're in uncharted waters but make sure to get a system rated for about the same weight as a Sienna.
Brighton is offline   Reply With Quote
Old 03-10-2020, 05:35 PM   #3
remcafee
So for a 99 sienna you have 2 options, either replace the rack and pinion assembly with a new one (not cheap) or you can bypass power steering all together by looping around the rack lines and get a drive belt with no power steering, only thing is it would be hard to turn standing still
Old 03-13-2020, 09:03 PM   #4
yaris9876
the stock system is hyd ram..not RP....what do you mean by drive belt?
I see on the net that there are elctric assist steering boxes that will do rack and pinion..and that is a kind of power steering.
No power steering on '08 Yaris after airbag recall done madradjessica DIY / Maintenance / Service 14 12-18-2018 09:14 PM
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 01:19 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
Steering wander, adjusting EPS assist Snubba Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-22-2012 06:39 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
