Old 03-19-2020, 03:34 PM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
Manual Yaris
Well, I was finally able to purchase a 5 speed Yaris. Does anyone know the transmission fluid change interval on the manual transmission Yaris? I changed my automatic at 100,000 miles, but I'm not sure what to do with the manual transmission. Thanks for any suggestions.
bentjazz is offline   Reply With Quote
Old 03-19-2020, 08:04 PM   #2
91mustang
Drives: Charcoal 2012 Yaris SE 5 Speed
There isn’t a requirement to change the fluid in the 5 speed transmission.
I’m at 131k, never changed it out.
91mustang is offline   Reply With Quote
Old 03-19-2020, 10:02 PM   #3
matti
Drives: 2017 Yaris L (5sp manual)
I asked my dealership this question in regard to my 2010 Yaris (5MT). Their response:
Toyota doesn't have a recommended mileage for transmission fluid. They recommend it gets inspected every 30K. Toyota now uses a lifetime fluid and may never need to be changed until the clutch needs replacing or maintenance.
FWIW.
matti is offline   Reply With Quote
Old 03-20-2020, 12:12 AM   #4
stidnam
Drives: Starlet
In the Maintenance section of your car manual it'll indicate that inspection is required every 40k km / 25k miles.
However, if you go to the end of the maintenance section, you should find an additional service requirements section. This section basically says that if you're constantly put your vehicle through extreme conditions, it'll need additional servicing. Those "extreme" conditions include
- Driving on rough, muddy or snow-melted roads
- Driving on dusty roads
- Towing
- Repeated short trips, less than 8km, in freezing conditions
- Extensive idling or low speed driving for long distances
- Stop-start city or suburban driving
- Continuous high speed driving at speeds greater than 140km for 2 hours
Under this section the recommendation is to replace the MT gearbox oil every 40k km/25k miles or every 2 years. Now before anyone points it out, I do understand that not all of the "extreme driving conditions" are going to warrant changing the gearbox oil.
In saying that, it's good practice and a rule of thumb to change your transmission oil every 80 - 100k km or 50 - 60k miles, or earlier if one of the aforementioned inspections reveals the need to.
Don't listen to anyone touting that an oil is a "lifetime" oil. There's no proper definition around "lifetime", and in my books it's deceptive marketing. Oils break down over time and with use. In the case of a manual transmission, changes are easy and the oil is cheap. It should be done periodically as routine maintenance, regardless.
stidnam is offline   Reply With Quote
Old 03-21-2020, 11:30 PM   #5
bentjazz
Thanks, guys. Loving this little manual Yaris more and more every day.
Old 03-24-2020, 10:56 AM   #6
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Congrats! No pics?
On Instagram
On Wheelwell
Old 03-24-2020, 12:01 PM   #7
bentjazz
Thanks, e-d! Will get some pics up soon, for sure.
Old 03-24-2020, 01:38 PM   #8
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
Old 04-26-2020, 12:05 AM   #9
bentjazz
As promised, a pic of my new used Yaris.
Old 04-26-2020, 03:29 AM   #10
Cool. Remind me, do the 2010 hatchbacks have tachs?
Also, I would change out the MT fluid every 60k or so. It's something easy, and gives extra assurance on keeping the transmission healthy. Make sure you change out the gaskets, and open the fill plug first before the drain plug, if you DIY.
Old 04-26-2020, 05:49 AM   #11
bentjazz
KL, unfortunately my Yaris does not have a tach. Why Toyota didn't put a tach on all of their manual Yari is something I don't really understand, but oh well. I have an Ecometer I bought from MicroImage way back when, and it has a digital tach. But it's just not quite the same thing. Plus, I have trouble seeing the readout in heavy sunlight. So....
I don't quite have the level of know-how to change out my own tranny fluid, but I'm learning DIY here and there. I'm going to attempt my own oil changes soon, so who knows. I kind of feel changing out tranny fluid requires a level of expertise that I just don't have and, in my luck, if attempted would end up in some sort of catastrophe.
Old 05-13-2020, 09:06 PM   #12
blktiger60
blktiger60's Avatar
Drives: `08 HB S
My S model came with a tach
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Question about Yaris manual transmissions JudgeM General Yaris / Vitz Discussion 9 02-23-2014 10:41 PM
Does anybody have the 2011 TMMF Yaris owner's manual? alexei General Yaris / Vitz Discussion 2 09-05-2013 04:20 PM
Got a quote on a 2012 Yaris L 3-door (5-spd manual) matti New YARIS Purchase Forum 28 10-12-2012 01:30 AM
