Old 06-02-2007, 08:02 AM   #1
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
Send a message via MSN to Sway84
sub question wanting pics
anyone put 2 12's in their HB?
pics please
Rice on, Rice Off
Ron Cabading
Sway84 is offline   Reply With Quote
Old 06-03-2007, 08:12 AM   #2
Ranggarn
Ranggarn's Avatar
Drives: Yaris 3Door YRX
I got 2 15's.. This is what they look like
Ranggarn is offline   Reply With Quote
Old 06-04-2007, 04:08 AM   #3
Highcom
Drives: yaris luna
So beautifulllllllllllllll
i would like a sub like you too, but how can i put the cables on the OEM cd player? and how can i dismount the cd player out?
Highcom is offline   Reply With Quote
Old 06-04-2007, 06:28 PM   #4
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I had two twelves and an amp in a custom box that kept the parcel shelf intact - you couldnt see what was in the car without lifting the hatch.
Ive since pulled them out and repaced it temp. with a single twelve.
If you want to keep the stock deck use a line output converter. I still have a brand new 4 way adjustable LOC from peripheral if anyones interested. Its yard sale time so itll be going either way.
mikeukrainetz is offline   Reply With Quote
Old 06-04-2007, 06:49 PM   #5
BlueFlash
wa do dem
BlueFlash's Avatar
Drives: 2007 blue Lb
Wink
use a line out tied into the rear speaker outputs make sure you get one with a gain control on the line out
BlueFlash is offline   Reply With Quote
Old 06-04-2007, 10:54 PM   #6
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
i love that setup of two 15s and the setup for 2 12s
what would you suggest for an amp to run two alpine r type 12 inch subs?
and where did u get ure boxes done mike?...im a fan lol'
Rice on, Rice Off
Ron Cabading
Old 06-05-2007, 08:25 PM   #7
JustYYaris
Drives: 2007 Blazing Blue Hatch M/T
1000 watts RMS should just about do it
JustYYaris is offline   Reply With Quote
Old 06-06-2007, 11:17 AM   #8
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
but then i would need another amp for my speaker components right...a 4 way channel?
Rice on, Rice Off
Ron Cabading
Old 06-06-2007, 04:20 PM   #9
mikeukrainetz
id recommend two amps.
I built the box myself. My job is sitting at a desk doing cad for 8+ hours a day and I worked construction for 13 yrs so not a tough job.
The boxes weigh a ton, I would recommend glassing a similar simple shape. Glassing will allow you to control shape / volume better than an MDF box - seems to me anyway. Maybe someone else could chime in.
For the price of some good cheap decks these days its almost not worth using the stock decks.
Old 06-06-2007, 07:43 PM   #10
sort_o_sane
Yaris GSR LOL
sort_o_sane's Avatar
Drives: 07 Yaris Hatch
Why with gain control? If a sub is gettng installed there will have to be an amp which has gain control, why double gain controls? I don't understad.
07 Yaris hatchback purchased in Dec '06. April 2015 and 103k miles, brakes finally needed changing, original battery finally died. I love this car.
sort_o_sane is offline   Reply With Quote
Old 06-06-2007, 09:40 PM   #11
BlueFlash
wa do dem
BlueFlash's Avatar
because a stock head unit puts out low amplitude and has no frequency adj with gain at control on a line out you can adjust the power before it gets to the subs so the amp is getting a stong signal so the amp will send a better signal to the subs it wont efferct sub gain just responce in general it does make the subs operate better
Old 06-07-2007, 01:17 AM   #12
sort_o_sane
Yaris GSR LOL
Now that makes sense. I will borrow your advice for my own car.
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
New pics Of My Yaris :) Meldav86 Photo-Video-Media Gallery 12 05-29-2007 11:23 PM
Deals Gap pics HTM Yaris Photo-Video-Media Gallery 3 05-15-2007 06:02 PM
Power lock conversion question mybabygirl DIY / Maintenance / Service 9 04-08-2007 07:47 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
