Old 10-18-2020, 03:44 AM   #1
ravipasupuleti
Drives: 2013 Yaris LE
Question Has anyone installed wheel spacers/ custom tires on 3rd Gen??
Hi All,
I like to have swap my yaris with a low profile tires ( 195/50/R15) and add spacers so they stick out of the fender. Researching on options available and came across the below spacers. Has anybody installed spacers on a 3rd Gen?? Would there be a ride height rubbing problem loading weight/ people on the back.
Also, can i go with 195/50/R15 tires. online stores show these are not compatible. any suggestions please.
Here is the product,
https://www.fitmentindustries.com/st...n-bora-spacers
2013 Yaris LE, 5 Door. Custom Wheels, 2ZZ TB Swap. Planning for a 2ZR swap in future.
ravipasupuleti is offline   Reply With Quote
Old 10-18-2020, 11:12 AM   #2
Alain93
Drives: Yaris 12
Hi,
I have some 205/50/R16 with 10mm spacers, and also lowering springs, it rubs every time I encounter a depression on the road or when I have with kids in the back. Didn't use to rub before spacers. But with original car height you should be fine.
Also, the wheel have 4 studs, so the spacer shown on the link will not work. And if you want to check what tire size is matching the original go to tiresize.com.
Alain93 is offline   Reply With Quote
Old 10-18-2020, 05:44 PM   #3
Personally I find tires poking out beyond the fenders looks like shit. Add to that a wheel/tire combo roughly 1 inch less in diameter than stock, double shit. Just my opinion. It is your ride.
Old 10-18-2020, 08:07 PM   #4
Alain93
Drives: Yaris 12
Is he your neighbor? If not, that:s good, so you will not have to look at it everyday.
Old 10-19-2020, 07:40 AM   #5
ravipasupuleti
Thank you Alain93. spacer link i shared is an example. The vendor does a made to order based on vehicle information. Thank you for the heads up.
Wheels sticking out is my thing may be, i like the look of wheels poking out.
DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) CTScott DIY / Maintenance / Service 12 01-22-2022 04:09 AM
Perfomance Upgrades for 3rd Gen Yaris?? ASkerritt Third Gen Yaris General Discussion 2 07-07-2019 01:21 AM
3rd Gen Sport Pedals ? NYC-SE Cosmetic Modifications (Exterior/Interior) 14 11-10-2018 09:46 PM
2nd vs 3rd gen ride quality + durability chocolab Third Gen Yaris General Discussion 23 11-17-2014 08:30 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 07:58 PM
