![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
Lower Control arm inner rear bushings
So it sounds like I need to replace the inner rear lower control arm bushing for my driver side. I thought it was my sway bar end links. I guess I might as well replace all four lower control arm bushings.
D586F4DC-0F3F-4995-9E52-D4AF1DDE40AD.jpeg I was looking for maybe a polyurethane replacement to make it last longer, but the ones that I’ve found are solid, which doesn’t have the groove like the OEM to make it more flexible. https://www.ebay.com/itm/Polyurethan....m46890.l49286 Should I stick with the OEM style? |
What kind of noise is it making?
It creaks and clunks over bumps.
Found a video of how to replace the bushings. At about 5:48 he demonstrates the creaking noise I was talking about. https://www.youtube.com/watch?v=0jKcJMLEEPk&t=458s Last edited by Neinris; 04-09-2021 at 12:38 PM. |
Also, I found a polyurethane OEM version:
https://www.ebay.com/itm/06-18-Yaris....c101195.m1851 Should I get this instead of the solid one? |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
if you dont mind squeaking and creaks go poly, you can put all the lube ypu want on those, they still will make noise, they work fantastic though
#6 | |
| Removing lower rear spring perches? | lormagni | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-26-2015 04:40 PM |
| Lower control arm bolt replacement | sully | DIY / Maintenance / Service | 6 | 01-15-2015 09:49 AM |
| P1 rear wiper arm on P2 | Chariz | Cosmetic Modifications (Exterior/Interior) | 1 | 10-12-2014 06:08 PM |
