Old 12-11-2017, 12:45 AM   #1
govtec
DIY: OEM JDM HID Headlight Conversion
Hi All,
Look what I got early for Christmas this year. Yup, just received my order from Buyee for a pair of JDM HID Headlight from Japan. I actually got 2 sets (ordered the post-facelift by accident). I will be using the pre-facelight for my wife's 07 Hatch and plan on selling the post-facelift once I'm done with the DIY write-up.
Now here comes the hard part. I'll need everyone's input to make this project a success and everyone else will have a chance to do the conversion. Specifically, I need part numbers that I need to order for the pigtails without cutting any wires coming from the car.
Enviri - Feel free to chime in since you've already completed this project in another post. Do you mind sharing the male/female pigtail plugs that I need to purchase?
Thank you all! I've done this JDM HID conversion on my 09 Rav4 and it makes a world of difference driving at night!
govtec is offline   Reply With Quote
Old 12-11-2017, 08:57 AM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
Old 12-11-2017, 09:25 AM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
hmm it looks like you already got the ballasts included (i hate you for that)
90980-10942(x2) is the female 4 pin connector you need.
(luckily it seems someone is selling one with wires already put in place, https://www.ebay.com/itm/90980-10942...t/351993047230)
then you need to ebay a quality h4 female pigtail connector, and a 194/t10 parking light extension cable.
then of course, a D4R bulb (NOT AN D4S, D4C may work.) and H7 for the super useless highbeam.
D4R in america is used in 06-09 prius, and 08-10 avalons.
GARAX and TOM's makes great bulbs outside the traditional OEM color range, that wont destroy the wallet btw...
CTScott helped alot on details of connecting the wiring, and he added an extra ground somewhere, which i forget.
Old 12-11-2017, 10:33 AM   #4
Whiplash
Drives: 2009 Yaris 4DR
I would like this, depending on total price.
Whiplash is offline   Reply With Quote
Old 12-11-2017, 11:21 PM   #5
govtec
Thanks enviri, I'll get the ordering started. My headlight pretty much came with everything including all the bulbs and ballasts. Am I still good to use the D2R bulb? It says on the side of the marking D2R 35W. The highbeams were a real pain to take out because the retainer clip was on pretty tight. Luckily I won't be changing this that often.
Also, if you take a look at img1141, it shows the the top half of the HID projector beam inside the case. Unlike my Rav4, which I had to reverse the metal plate that was inside the projector casing, it appears that with the Yaris there is no metal plate on the inside and you can adjust the beam pattern from left hand side to right hand side by just using a screw driver.
Enviri - On the last image, can you get met started on which of the 4 wires are connected to the H4 connector?
Thanks
Old 12-12-2017, 10:41 AM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
if it already has d2r then first check the part number of the ballast, and stay d2r.
wiring i have to get back to you.
im pretty sure green is the parking light, and black is common ground. our headlight has a switched positive setup (or is it switched negative?), i gotta pop the hood and check it out once weather permits.
Old 12-12-2017, 03:52 PM   #7
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
H4 Connector is switched ground. Low and Hi has their own ground pin.
Based on Enviri connector photo and pin orientations im guessing
Red Low Beam
Black Hi Beam
Green Parking
Black 12v.
Check out my Build thread:
Old 11-15-2018, 08:01 PM   #8
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Red Low Beam
Black Hi Beam
Green Parking
Black 12v.
Hi all,
I know this is an old thread but I just found it recently and ordered a set of JDM HID headlights for my ride.
I was hoping to get clarification on the wire orientation to connect from the H4 to the HID connectors.
Black is quoted as 12V, Hi Beam, and in some cases, Ground.
Could you please help me out with the correct orientation.
Thanks in advance,
DeeBee
DeeBee is offline   Reply With Quote
Old 11-25-2018, 01:42 AM   #9
govtec
Originally Posted by DeeBee View Post
Hi all,
Thanks in advance,
DeeBee
What I did was basically followed the orientation of the 4 prong pins that enviri showed in the videos. If you do that you should be fine and just trace it back to the plugs in the headlight to confirm the orientation.
Old 12-13-2018, 05:49 AM   #10
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Thank you for your help. I was able to get the wiring done.
I tested them with a battery charger and they worked well
When I plugged them into the car the HID do not come on
All other lights turn on. I know the bulbs work so it must be something to do with the car's stock wiring. I get the feeling there is not enough power to turn on the HID ballasts. I am not using a wiring harness.
Is everyone who has them working using a wiring harness? Please help me solve this before Christmas. I'd like to have them working for a road trip then.
Regards,
DeeBee
Old 12-13-2018, 07:03 AM   #11
IllusionX
Drives: 07 Yaris Sedan Aero
The Yaris have a ground switch. You may have the wires reversed
Sent from my CLT-L04 using Tapatalk
Old 12-13-2018, 11:39 PM   #12
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
BTW govtec,
The videos aren't available any longer so I'm not able to see if indeed my wiring is off.
Regards,
DeeBee
Old 12-14-2017, 01:19 PM   #13
fredovvti
Drives: Yaris 07 HB
How much you pay for shipping?
fredovvti is offline   Reply With Quote
Old 12-15-2017, 12:50 AM   #14
govtec
I think $110
Old 01-12-2018, 12:23 AM   #15
govtec
Now that I'm catching a break from the snow and all my harnesses have finally arrived. I'm hoping to install this soon. Enviri - Any luck with getting the wire connections from your car? Just need some wire identification so I can solder the 4 to 3 prong harness. Also, I'm not sure where the 194/t10 parking light extension cable goes because I don't see any plug holes left for me to put this in the headlight. I took the little light bulb out in the picture and tried connecting the 194/t10 extension cable but that plug was fine with without any extension cable.
Thanks
Old 01-12-2018, 10:52 AM   #16
enviri
enviri's Avatar
Drives: 2010 Yaris
I, too am at the mercy of the weather. Yesterday was perfect but i read this post near midnight lol. Today is warm but gettin some monsoon rains...
Anyway heres a quicky
https://youtu.be/F7PloYRGlrE
Parking light ground i think is connected to chassis. I need a good calm day to rip apart my headlight!
Old 01-12-2018, 01:14 PM   #17
enviri
enviri's Avatar
Drives: 2010 Yaris
Also you might start poppin fuaes on headlight use like i did. I went against ctscott's recommendation and went +5a... Although i think +2.5a is enough, maybe?
Old 03-25-2018, 05:03 PM   #18
fredovvti
Drives: Yaris 07 HB
Where you change the fuses?
Sent from my SM-N950F using Tapatalk
FS: 2012 Yaris oem headlight projector retrofit ucsmfu Items for Sale by private party 4 11-01-2016 11:28 PM
How can i get the OEM Headlight Stalk with FOG switch to work murtaza.shahid DIY / Maintenance / Service 0 11-22-2014 07:30 AM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 02:40 AM
FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal 03Z33 Items for Sale by private party 30 01-02-2009 07:55 PM
DIY - JDM RS style REPLICA tails kurokoma-kun DIY / Maintenance / Service 0 10-21-2008 03:56 PM
