![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
no HVAC lights, no headlight buzzer
hello. so i removed my aftermarket tachometer, and am getting ready to install my new tachometer. i had the illumination light wired directly into the lower fuse box on old tach. when i was running wires for new illumination, i found a wire tap installed on dimmer adjustment rheostat. i though it might be nice to dim the new tach, so i connected wiring to tap in. the other side was not connected yet, i was just running wiring. after that, i lost HVAC lighting, and speedometer does not dim when turning on headlights. buzzer is not functioning for "lights on warning." i disconnected the installed dimmer switch wire. i have checked all under dash fuses and under hood fuses. i can not seem to find where the issue is. headlights, parking lights, DRL's, tail lights all function normal. i've done a search for this issue, but there is not a clear answer on any posts. i've seen mention of the dimmer switch, and panel 1 and panel 2 fuses, but i can not seem to locate these fuses.
do you have a solution for me? thanks! |
i could figure it out, but i can't seem to find a wiring diagram for interior lighting.
is there one on this site somewhere? |
i found it! panel 1 fuse was the issue. fuse was fine, but installed in the wrong fuse row! the panel 1 slot was empty. i must have pulled it and installed it into an unused slot by mistake! what an idiot!
if you are looking for a pretty good wiring diagram that you don't have to sign up for or purchase: https://sakhsondotcom.files.wordpres...ng-diagram.pdf |
![]() Drives: BMV X5 Join Date: Feb 2021
It was a great decision! Thank you for sharing this with me this, I was just looking for a solution to a similar problem! Of course, it was stupid of me to look for this for so long, because your post came across me several times in the suggested ones on this forum, but for some reason I constantly missed it. If I had known that there was a solution here, I would have been able to sort out my difficulties much faster. I think it would be a good idea to start training and become a real professional in repair. What do you think about it?
| Tags |
| dash lights, hvac lights, no buzzer, no lights |
| Dashboard lights and exterior park lights going off | NXyaris | Suggestions - Feedback - Questions | 2 | 09-09-2016 04:46 PM |
| diy HID projector w/ halo headlight install | tmontague | DIY / Maintenance / Service | 17 | 02-04-2016 11:34 AM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| Headlight Indicator, Gear Lights, AC Lights All Out | Hardicus | DIY / Maintenance / Service | 15 | 11-09-2013 05:50 AM |
| headlight liner parking lights... | Kioshi | Cosmetic Modifications (Exterior/Interior) | 9 | 02-10-2010 03:06 AM |
