Old 10-26-2020, 07:54 PM   #1
Format
Drives: Toyota Yaris
Hello everyone,
I think is a good idea to share my experience with the installation of Atoto SA102 Starter unit in my Yaris 2007 (XP9) (European Car).
List of things that you need to buy:
* Atoto unit (in my case I choose the SA102 Starter unit)
* CTSTY001.2 from connects2
* CTMULTILEAD.2 from connects2
* Yaris frame for install 2Din unit
With this things you can easily install the unit with fully functional steering wheel controls.
In my case I only solder 3 wire, the rest of the wires I use the ISO B connector cable that came with the unit. It was super easy.
In the wires that came with the unit you have 3 wires for steering wheel, that you need to connect to the CTMULTILEAD.2
Steering wheel GND => GND
SW Key => Key 1
SW Key# => Key 2
With this you have the unit fully functional with the steering wheel controls.
1) This is my original yaris unit
2) This is the final result after install the SA102 Starter unit
3) The 2Din frame that I bought
4) The list of things that came with the unit
Has you can see in the picture number 2 I fill the gap of the unit and the frame with a silver bezel that came with the phonocar frame. But when I have a little of time I will try with the black bezel that came with the Atoto unit (see picture 4).
I hope the information that I published help someone to install the Atoto unit.
I also saw a few videos with tutorials works before install the unit. This is the list:
https://youtu.be/ygRz5dzpGR0
https://youtu.be/-kUOZVb8XKU
https://youtu.be/Ja6cLDWXLto
https://youtu.be/r7GlDBge_WU
https://youtu.be/AcqWHIRSaIk
https://youtu.be/aSQTje4sXfs
https://youtu.be/FuSUm9F32hE
https://youtu.be/c-0x05_si58
https://youtu.be/htC2hpzHQ_M
https://youtu.be/vIfZQd0wpg4
https://youtu.be/PAUm17NNXPM
https://youtu.be/o1gqoGeyMeY
Format is offline   Reply With Quote
2007, 2din, atoto, sa102, steering wheel
2007 Sedan HU, Amp, Speaker install Crackerballer In Car Entertainment + Electronics (audio / video / alarm) 15 11-14-2011 07:47 PM
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
