Old 06-29-2021, 04:32 PM   #1
BarryYaris
Drives: Yaris MK2 Vvt-i 1.33
Exclamation Yaris LED flasher relay problem
Hi, new to this forum after recently purchasing a MK2 Vvt-i 1.33 Yaris.
Decided to swap pretty much all the LED lights with either Osram or Phillips.
All went well until I got to the flashers/indicators. I've got another Toyota so knew straight away about needing to swap out the relay.
The problem is, that despite swapping out the old flasher relay, the lights are still in hyper flash. I thought the relay night be faulty so swapped it with the one from my other car which works perfectly and I still get the same problem.
Has anyone had the same issue and found out the reason for this?
Cheers guys!
BarryYaris is offline   Reply With Quote
Old 06-29-2021, 08:06 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Not sure if the mk2 is the same, but I ran across this with my 2012 series 3. The series 3 flashers are controlled by the ECU, with no flasher relay. The only way to stop the hyper flash rate was to put suitable resistors in parallel with the LEDs.
These ended up with a 6 ohm resistor across each LED. The resistors need to be rated at least 20 watts to avoid them failing, but 30 watts would be safer. The ones I got had a finned aluminium casing complete with mounting holes so they could be fixed in a suitable position for cooling air flow.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 07-03-2021, 05:31 PM   #3
BarryYaris
Thank for the reply kevinj93.
After checking the wiring diagrams I found it's definitely not controlled by the ECU on the Mk2.
For some reason the standard LED relays don't seem to work, but I found this relay that was perfect. It's also adjustable so you can set the exact timings to you want:
Old 07-03-2021, 07:05 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Glad you found a solution.
flasher, hyper flash, led, mk2, relay
2008 Yaris Sedan Electrical problem VIP Asia 0 01-05-2016 02:49 AM
acceleration problem yaris 2012 sedan ahmedmhb Middle East 1 10-17-2013 05:32 AM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 04:46 AM
