![]() Drives: Toyota Yaris Join Date: Sep 2021
Hi, First post here :)
Well I have a Toyota Yaris and when I remove the ignition key its speedometer (digital) doesn't turn off and it's always drawing current from the battery. I disassembled the speedometer and tested it on the bench and when I disconnect the key wire the current is at 17mA and it doesn't turn off. Does anyone have any solutions? lengths, ReiZeMuitoGordo Last edited by ReiZeMuitoGordo; 09-29-2021 at 11:58 AM. Reason: Pictures |
How many amps does the speedo draw?
I think it's normal when everything is working it should be between 200 mA to 150 mA but as you can see from the images when it's on it's 180 mA and when the ignition is off it continues with 170mA and it should go to 0 after 1/2 seconds.
It possible to put an on off switch in the wire going to the speedo?
I had a motorcycle with an electric fan that would overheat in city Traffic but was fine on the highway. So I put it on off switch to turn the fan on as soon as I got in traffic. Bingo no more overheating!
| Tags |
| speedometer problem |
| Using turn indicators as DRLs on 2009 HB | tamrat | In Car Entertainment + Electronics (audio / video / alarm) | 26 | 09-11-2023 12:45 AM |
| Analog Speedometer instead Digital | Sesjusz | DIY / Maintenance / Service | 7 | 07-01-2014 11:42 AM |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| Projectors retrofit, black reflectors and dimmed front turn signals | my2sense | General Yaris / Vitz Discussion | 11 | 06-20-2012 11:39 AM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-28-2009 11:53 PM |
