![]() Drives: 2007 Yaris Sedan A/T Join Date: Oct 2021
Sealing Trunk Lid Rubber Seal
The rubber seal that grips over a metal lip (going around the opening for the trunk) works loose after 18-24 months, resulting in water entering the trunk and causing the tops of things sitting in the trunk to become wet. I have isolated this issue to the rubber seal because I can remove the seal and using a pair of pliers tighten up the 'clenching' strip inside the seal, reinstall the seal and verify there are no more water leaks.
Is there a waterproof, preferably non-hardening(?), sealer or caulk I can apply inside the clenching channel of the rubber seal (before reinstalling the rubber seal) to created a long-term solution ? Thank you for your feedback. |
| Trunk Lid Seal Replacement | Tumbleweed_2 | DIY / Maintenance / Service | 1 | 10-28-2021 08:39 PM |
| Rubber seal for hood/bonnet | artxty | General Yaris / Vitz Discussion | 3 | 10-15-2019 02:33 AM |
| HELP: New passenger side rear light rubber seal needed | kavos wildcat | DIY / Maintenance / Service | 5 | 12-16-2012 06:38 PM |
| HELP: New passenger side rear light rubber seal needed | kavos wildcat | Items for Sale by private party | 0 | 12-16-2012 09:15 AM |
| Trunk Lid Swap | 07typeS | Items for Sale by private party | 11 | 09-01-2007 10:32 PM |
