Old 12-01-2021, 12:44 PM   #1
Igorkarevski
Drives: Toyota yaris
Toyota Yaris 2004 wipers problem
Hello guys, i got toyota yaris 2004 and the wipers only work on high speed. Also when i turn on the washer wipers wont turn on automaticaly. So i watched a video for replacing the relay but i dont know if thats the problem, i de mounted the unit cleaned the electrnics with contact spray but that solved the problem for 24 hours and here i am asking what to do next? Thank you very much
Igorkarevski is offline   Reply With Quote
Old 12-07-2021, 02:32 PM   #2
Rich_UK
Drives: Yaris mk1 & Yaris mk2
Not sure if i read that right?!? Well if that solved the problem then there's the fault!??
If it were me i would make sure its not a loose connection by wiggling the wires whilst testing, if that doesn't wake it up id respray the contacts on the relay or tap it to see if it brings it back if so I would look a the part number and replace it.
Rich_UK is offline   Reply With Quote
2020 Toyota Yaris – first compact TNGA-based model; Dynamic Force engines, Advanced P toyotavios_11 Third Gen Yaris General Discussion 16 11-02-2019 06:45 AM
