![]() ![]() Drives: Vitz RS 1.5 Join Date: Feb 2009
DIY : How to remove door panels
This is my contribution to Yarisworld. THis is what I am cataloging as I am going along with my yaris build. I am hoping it might help somebody.
This is done on a liftback 2009 Vitz RS. Starting on the left hand door. Remove the armrest piece. It just pops upwards. ![]() This is just another illustration of the same piece that should pop up. On the other end of the door, use a small screwdriver to pop open a cover as shown in the photo. ![]() This is what it will look like after taking off the piece. ![]() Proceed to remove the power window switch panel and the other panel illustrated in the photo. These should both pop up as well. No tools required, just use your hands. ![]() Remove the connector for the power window switch by pressing the tab and pulling. ![]() This is what it looks like after removal of the above 2 pieces. ![]() + screwdriver required. Remove the 4 screws as shown in the photo. ![]() To remove the door card, I pulled anywhere along the bottom of the door. It will come apart as shown. ![]() It might require quite a yank to get it to come off. After it has seperated from the door, push the door card UPWARDS, it should come free after that. Remove the door / lock wires from the latch. These are where all the little grommets are located in order for you to re-attach them to the door card for installation. ***There is one more behind the hand.***. ![]() I hope this help. :) |
hahah I just did that this morning from an old DIY, but arigato, your pics are quite clearer!
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Ok, now I have no excuse for not pulling my door panel off to do sound deadening. Thanks for the DIY.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
the ubernigga
Drives: 2008 Yaris 3D HB MT Join Date: Oct 2008
Note that if you have manual windows its a little tricky to remove the crank.
#6 | |
I took off the plastic sheet then I had to remove all that sticky black silicon. I used selo tape and just stickied it off. ![]() ![]() All done, nice and clean ![]() Then applying the sheets should be pretty straight forward. I am going to have to re-do mine as I am not happy with the way it turned out.
Did you put any deadening material on the inside of the external door skin or just cover those holes on the inside as seen in the photo?
External skin deadened, but didn't have time to take a photo. I am not finished with the deadening yet, waiting for my speakers to arrive. Then I have to get baffles and then I will deaden the door again and also over the baffles.
Modded Moderator
Where is the DIY for the manual windows? Trying to figure out how to get the crank arm off.
Should be a spring clip behind the crank handle. Push on ur panel slightly and look behind and should see a horse shoe shaped clip. You can either remove it with a special tool which is the easiest (Harbor freight or autozone for about $5-14) or a flat screw driver or a pick will work. Careful they shoot out sometimes and are easy to lose. Pretty sure the yaris is the clip type (i have power windows), if not it can be a cover type that u remove and swing out of place to reveal a torx screw or bolt.
Yaris beginner
The pictures are dead :( Can anyone repost or something? I'm getting some new speakers soon :)
#12 | |
#13 | |
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
photos???
What images? |
![]() ![]() Drives: Yaris 2009 Join Date: May 2021
Following
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| DIY Variable Speed wiper stalk install | DanQ | DIY / Maintenance / Service | 27 | 08-03-2017 08:22 PM |
| DIY Powered USB Ports | BailOut | DIY / Maintenance / Service | 27 | 02-22-2017 11:17 AM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 07:52 PM |
