![]() Drives: Yaris Join Date: Dec 2021
Does anyone know what this annoying rattle is ?
https://www.youtube.com/watch?v=Y9Oc...b_channel=Slim It mainly does it when in reverse when I lift off the clutch, sometimes in first gear but never when I'm driving around. Yaris MK2 2008 Thanks |
Unfortunately I haven’t a clue but it sounds pretty bad.
Have you taken it to a mechanic?
#3 | |
Could it be the heat shield underneath ? As it does look a bit loose |
Definitely does not sound like a heat shield!
A loose heat shield does in fact rattle while driving. But your noise is much more serious than a heat shield.
You need to consult a mechanic!
OK thanks. I'm booked in for next week.
Any speculation on what it could be? It only happens when in reverse and the clutch is up. |
I found a thread on it here. Apparently it's the type of exhaust system the yaris has ..
https://yarisworld.com/forums/showthread.php?t=1774 |
Mechanic said it was a rubber exhaust mount needed lubrication. Now it's fine
| Rattling sound on Yaris when A/C is off | Yaris044 | DIY / Maintenance / Service | 13 | 09-03-2020 11:42 PM |
| Rattling sound car running foot on brake ? | YodaBird | General Yaris / Vitz Discussion | 0 | 04-28-2018 06:55 PM |
| YARIS 2005 Rattling sound | mik23 | DIY / Maintenance / Service | 6 | 05-15-2016 05:34 AM |
| Various problems with service at shop (green coolant and accelerator rattling noise) | LilyOfTheYaris | DIY / Maintenance / Service | 4 | 04-08-2014 10:31 PM |
| Rattling sound when using reverse gear | Swallow | General Yaris / Vitz Discussion | 5 | 06-17-2009 01:47 AM |
