Old 04-17-2019, 02:45 PM   #1
carstudiopk
Drives: Toyota Belta 1.3, 2008, 3SZFE
Steps for Good Fuel Economy
General maintenance helps in maintaining a good fuel economy. Following is a checklist of services which should be done periodically.
MAF sensor cleaning (twice an year)
OCV valve service (once an year)
PCV valve service (twice an year)
Throttle body cleaning (twice an year)
TPS sensor cleaning (twice an year)
AFR sensor cleaning (4, 5 times an year)
Catalytic Convertor unclogging (depending on condition)
Fuel filters cleaning (twice an year)
Engine Flush (twice an year)
Always use genuine air filter, oil filter from Toyota 3S dealerships
Use engine oil 5W30 ALI SN GF-5 of any Total, Toyota, Shell.
Check the plugs and Coils regularly. Don't service plugs. Change them.
Check fuel filter. Service then if clogged.
Do the decarbonisation of engine combustion chambers once an year.
Wheel balancing and aligned should be carried out atleast 3 times in a year provided if you use your car mostly within city.
Clean and wax the car for less friction and drag.
carstudiopk is offline   Reply With Quote
Tags
fuel economy, fuel efficiency, hypermiling, maintenance, service
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 326 02-15-2025 11:09 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 09:55 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 10:20 PM
