03-16-2022, 06:33 PM | #1 |
Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
ECU Reflash service…
Just want to share this to everyone if it hasn’t been posted…
https://christaylorracing.com/produc...a-toyota-yaris Increases the REV up to 7400RPM. |
03-18-2022, 01:12 AM | #2 |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Intriguing.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
03-20-2022, 12:55 AM | #3 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Only works for 2007 yaris as he specifies that you cannot have a yaris equipped with the factory alarm
03-20-2022, 07:18 PM | #4 |
0-60 in slow
Years don't matter issue is the factory alarm due to key-ecu mismatch, it was my car he developed the tune on. Tune works great on mildly modified engines.
It works on many different years. The factory alarm issue is a bigger problem because of the key and column and ECU are tied to each other and cannot be swapped with another part.
2014 BSpec Divisional Champion |
03-20-2022, 11:53 PM | #5 | |
Gen 3 > Gen 2
03-21-2022, 01:35 PM | #6 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
so do you tell him what mods have been done and he will tune the ecu accordingly? or is it just a preset for all kindsof setups? how about drivability and emmisions? im kinda interested
03-21-2022, 07:33 PM | #7 |
I can’t speak for the company, I’m just sharing my find. Xnamerxx might be able to answer your questions. I’m more interested to know if they can also reflash the 2ZR ECUs. I’ll message them once I find a donor car.
03-23-2022, 06:06 PM | #8 |
0-60 in slow
I don't know if they've tried a 3rd gen but I know he had some ECU's so its possible.
There is some customization that can be done, but its a mailorder tune so there are some things that need to be done via dyno because it would be unsafe for the engine.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Change ECU No DTC codes, With Crank and Fuel Pressure not starting/no Spark | tatlogis | DIY / Maintenance / Service | 0 | 08-13-2021 12:24 PM |
Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
MWR AEM EMS 4 P&P ECU | tmontague | Performance Modifications | 3 | 02-09-2020 08:07 AM |
I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
