![]() Drives: 2008 Yaris, 4dr sedan, 5 spd Join Date: Mar 2023
3 keys - one key w/fob as handle 3 buttons
Whats the deal with the 3 keys.
1) I have one key that broke the key part of the fob handle w/3 buttons, alarm, lock, unlock. 2) I have a normal key with a big plastic handle that unlocks the drivers door but does not open the passenger door. 3) I have a another key, that looks like the previous key, but only opens the passenger door. The salesman said its the valet key. I'd like to have the fob buttons working with the key attached. I have just been using key #2 listed above to open the door, and start the car. Then I just use the power locks to open the other doors if I have a passenger. Clueless me, went to key cutting place, but he said he cant do it. Dealer was expensive. Looked for key blanks online, may have to go that way, or just keep with key #2. |
a valet key is no diffferent from a normal key with the exception of possible transponder codess, and should work in all locks
what you have is a missmatched set due to door/lock changes without knowing year and where it was sold its hard to give more advice, if its an "early" yaris then it wont have a transponder and any idiot can cut a key for it, if its a newer unit then you need the expensive transponder keys and they will have to be programed now about programing.."if" the key you have is the "master" key for the car or has been programed as the master, you can program spares yourself by way of the master key and some ignition combination on off etc as far as more "fob" type and programing them i belive the master key allows this too.. |
His details and posting history indicate a used 2008 sedan, Alberta purchased. Should not be a transponder key. My guess, vehicle had been damaged, passenger side, resulting in that door being replaced with a salvage door. Or, that lock barrel may have seized and was replaced. Either case, the second key which is specific to that lock.
![]() ![]() Drives: 2007 4dr sedan Join Date: Jun 2009
All cars sold in Canada after September 2007 are required to have anti-theft engine immobilizers hence the transponder keys. This also includes the valet key which may not unlock the glove box and/or the trunk.
| 2007 yaris replacement keys | Paul Leonard | General Yaris / Vitz Discussion | 2 | 02-15-2021 08:56 PM |
| Buttons on key stopped functioning | jambo101 | DIY / Maintenance / Service | 2 | 12-17-2017 11:22 AM |
| 2 keys to unlock doors/hatch/ignition (only want one key) | Cigar_Maverick | DIY / Maintenance / Service | 3 | 03-27-2017 09:04 PM |
| New remote key fob programming | costica | DIY / Maintenance / Service | 1 | 04-17-2016 09:02 PM |
| Transponder key programming | teddy | DIY / Maintenance / Service | 6 | 04-28-2015 07:32 PM |
