Old 12-02-2022, 06:48 AM   #1
loricechris01
Drives: Yaris
Fuel smell after filling
HI, I have been having an issue with my Yaris/Belta 2009 VVT-i model. I get an extremely strong fuel smell outside the car and inside the car cabin only after fulling the tank (No drips or mess during fulling). And the smell is extremely strong while driving to the point where the fuel smell burns my eyes. There are no signs of drips on the fuel tank itself, the fuel return line was changed and the fuel pump was temporarily sealed off to see if it'll help the smell. After the car loses a bit of fuel from usage the smell goes away.
Help! Does anyone have any advice?
loricechris01 is offline   Reply With Quote
Old 12-02-2022, 07:22 AM   #2
ex-x-fire
Don't try to add more gas after the pump clicks off.
Old 12-05-2022, 06:37 PM   #3
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
What he said
Overfilling will flood your fuel recovery system which is big buck$$.
alanwagen is offline   Reply With Quote
Old 12-02-2022, 08:05 AM   #4
bronsin
bronsin's Avatar
Take The car to a mechanic and have it looked at NOW!
Old 12-02-2022, 08:53 AM   #5
loricechris01
Drives: Yaris
I've had multiple mechanics check it for me and there wasn't a solution yet. Right now I'm just waiting for the fuel level to drop so that I don't get the smell
Old 12-02-2022, 09:18 AM   #6
bronsin
bronsin's Avatar
In that case I agree with the poster who said when filling the car with gas, don’t add any after the first click of the pump
Old 12-02-2022, 02:20 PM   #7
loricechris01
Drives: Yaris
I would have to do that from now on. But what do you think can cause an 'overfilling' issue for it to smell that bad?
Old 12-02-2022, 02:38 PM   #8
bronsin
bronsin's Avatar
There are hoses near the fill port they go to a charcoal filter which stores gas fumes. Probably some of the extra gas you were pumping in after the first click is going down that hose to the charcoal filter.
That can ruin the charcoal filter and the solenoid which turn things on and off in the system
It’s very unwise to pump gas after the first click
Old 12-02-2022, 06:04 PM   #9
remcafee
well you said it had recent work done i would suspect that right away, fuel leaks are not something to brush off, get that shit sorted fast as its a rolling fire hazard as it is now
Old 12-03-2022, 01:18 PM   #10
sh0rtlife
if your filling anything made after the mid 90s beyond the first click(unless it clicks off VERY early) your fueling things that shouldnt have fuel in them
old stuff pre 80s often needs to be seriously topped up as the pumps are too sensitive for them and can stop crazy early
if i was to place a guess your simply overfilling it and need to stop doing so, secondly the suspect would be the evap system or the tank to fuel seal
both options are viable and its pretty easy to know which based on how long it takes for the smell to go away....does it come back on a hard right hand turn?..if so its the tank seal
Tags
cabin, cabin air, fuel, fuel smell
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
