Old 08-03-2019, 09:39 PM   #1
Ricardo92345
Drives: Yaris
Where can I get a replacement for this?
The clear plastic on mine is dirty. I tried cleaning it but no luck.
Sent from my ONEPLUS A6013 using Tapatalk
Ricardo92345 is offline   Reply With Quote
Old 08-04-2019, 04:59 AM   #2
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Pre facelift 11-14
https://www.toyotapartsdeal.com/oem/...852-5cb20.html
Facelift 14-
https://www.toyotapartsdeal.com/oem/...=meter,,83138G
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 08-04-2019, 07:15 AM   #3
bob225
Drives: Yaris
what have you used to clean it ? a very mild cutting compound should be able to remove most of it if not all (you could try toothpaste)
if its on the inside pop the cluster out and remove the lens
bob225 is offline   Reply With Quote
Old 08-04-2019, 04:32 PM   #4
Ricardo92345
Drives: Yaris
I think I tried water at first. It look like it worked but when it dried it showed up. Then I tried window cleaner and the same thing happened. Bought the car used and it came like that.
Old 08-04-2019, 11:15 PM   #5
yarisbug
yarisbug's Avatar
Drives: 2010 1.4 d4d
This will do it for you, no need to replace it. This stuff is magic, Plexus -- https://amzn.to/2Yk20tU
yarisbug is offline   Reply With Quote
Old 08-05-2019, 09:43 AM   #6
bob225
Drives: Yaris
Its more than likely a silicone and its been baked by the sun, IPA (isopropyl alcohol) should remove it
Old 01-25-2020, 12:32 PM   #7
G6-R
Drives: CHR 1.8 Hybrid + Yaris gen3
Take the complete speedocluster out ande take the glass off an clean the inside of the glass olso than it must be fine.
G6-R is offline   Reply With Quote
Old 11-12-2022, 09:49 AM   #8
markyoung
Drives: yaris
You can try White vinegar and Isopropyl alcohol for cleaning. I have cleaned mine by using these two products at home and it works :)
markyoung is offline   Reply With Quote
Old 11-12-2022, 03:20 PM   #9
remcafee
you can buy replacement screens from the dealer, remember, every single part is replaceable on your toyota
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 05:20 PM
Bumper replacement mchamp00 DIY / Maintenance / Service 0 07-03-2015 11:45 PM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 01:33 PM
Reliable Source for Replacement Parts wagon DIY / Maintenance / Service 4 03-06-2013 01:56 PM
