![]() Drives: 08 yaris Join Date: Sep 2012
Rubbing noise after installing drum brake
Hello, I have a 2008 Sedan and recently had my brakes replaced. The drum brake on the rear passenger tire rubs the inside of the wheel cap when I drive for 5-10 minutes. I've had my mechanic brother look at it and he has tried to adjust the brake to make it set closer to the bearing, shave the side of the drum brake that was rubbing, and replaced the bearing altogether but it still rubs.
Has anyone had this issue before and maybe had a solution not already tried? Thanks! |
sounds like a wrong shoe or wrongly installed shoe
I'm not getting it, is the drum rubbing the backing plate?
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
Wheel is rubbing on the hub? Can you please make a video to show us?
thats another couple thoughts, wrong drum, bad bearing
I'm lost as to what 'wheel cap' is.
| Drum Brake Issues | Thirty-Nine | DIY / Maintenance / Service | 10 | 04-01-2022 12:48 AM |
| Which brake drum brand should I buy? | Rob888 | DIY / Maintenance / Service | 7 | 10-25-2021 06:17 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 07:05 PM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 09:05 AM |
| Drum brake problem. | theb | DIY / Maintenance / Service | 4 | 04-23-2014 03:04 AM |
