![]() Drives: 2007 Toyota Yaris Join Date: Feb 2023
ABS pump motor sound?
I just got this Yaris a few weeks ago and one of last annoyances to sort out is the short buzzing sound when I get the car moving. It sounds like an electric motor starting up. It only happens once or sometime twice when I get the car moving then it stops and no more sound. I think it's the ABS motor behind the battery because that where the sound seems to come from. Any ideas?
See if you can remove an ABS fuse or relay to see if the noise goes away. You might want to get the ABS system scanned for data & codes.
Okay I took out the ABS1/VSC1 fuse from under hood fuse box. No sound but of course the ABS light went on. When I put the fuse back in and started it again, the light stayed on until it made the buzzing sound. Then it went off so it's definitely the ABS motor. I think the brushes may be worn. There's kits available to rebuild just the motor. Has anyone here ever done this?
https://www.ebay.com/itm/38201439033...mis&media=COPY
In Hawaii will a car pass inspection without the ABS working? If so, there’s no need to fix it. Statistically, ABS has not resulted in a substantial lowering of the accident rate or fatalities. Yes, it’s very impressive when you put it to a demonstration, but practically it doesn’t do anything to make you safer. Watch YouTube dash cam videos of accidents and you can see a very good demonstration of this. Somebody does something stupid somebody else slams on their brakes to avoid the stupidity and the cars collide anyway.
If you want to fix the brakes, you probably just need to replace the ABS module. But that Hass to be synced to the car is computer I bought a pick up truck at a used car lot and the ABS didn’t work. The guy had to replace the module and it took like a month in New Jersey. Your car won’t pass inspection if the ABS doesn’t work. It’s like synthetic oil, ABS is just an illusion imposed on a gullible public. Don’t believe it? Ask your insurance company if you get a discount for ABS brakes there isn’t any.
#5 | |
The ABS works fine. It just makes a short buzzing noise when I first get the car moving. I should probably just leave it alone unless someone has specific instructions on how to rebuild the motor.
I found this about the ABS: Quote:
This is what I'm hearing but I'm sure it shouldn't be so loud. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
Since my car is not equipped with ABS, I have no idea what normal should sound like. Keep in mind that these cars have basically nothing for sound dampening so little noises are easily heard. I say leave it be and if it eventually fails, so be it. It won't be like the car suddenly becomes un-drivable.
| Fuel pump upgrade... | Neinris | Performance Modifications | 31 | 12-16-2024 04:27 PM |
| ABS Code Keeps Returning After Sensor Replacement Code 31 Front Right | Chwbcca | DIY / Maintenance / Service | 5 | 09-15-2021 09:16 AM |
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 09:55 PM |
| Car shuts off when A/C turned on... | Howster | DIY / Maintenance / Service | 33 | 07-06-2013 06:00 PM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 07:04 PM |
