Old 01-19-2023, 06:32 PM   #1
sh0rtlife
slightly off engine swap questions xb vs yaris
ok so ive been digging and the reality is that there is more information here than any other place ive looked..but ive exhausted my searching so im left to ask
how different is a first gen scion xb from a yaris SPECIFICALY in the engine bay
we might be grabbing a cheep clean blown engine XB...05?, and im fully aware it uses the EXACT engine our lil yari' do, so my brain got thinking..if it needs an engine why not do a swap?
if the 2zrfe fits and works in a yaris certainly it should be pretty much the same swap in an XB....but everything ive seen in regards to said swap on a yaris always leads to a lil confusion around the ABS and generation of the car
so lets say i wanted to swap the 2z into a 07 yaris..what rules change?..and what rules change in regardes to NON abs?
ill know more on the scion this weekend
Old 01-20-2023, 12:34 AM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
Should be pretty much the same job, its the same car with a different body shape really. But their are scion forums Ive seen just like this that have all that info. Could try asking here https://www.clubxb.com/forums/
Compeer is offline   Reply With Quote
Old 01-20-2023, 12:50 AM   #3
sh0rtlife
most of them seem to be just as dead tho
but something ive come across that has peekd my intrest is that the scion XA aperantly has rear disc brakes and 14inch wheels AND its a direct bolt on to the vitz/yaris.......
Old 01-20-2023, 05:44 AM   #4
Compeer
Yeah same rear trailing arm, you would only need the yaris hand brake cables.
Old 01-20-2023, 12:25 PM   #5
sh0rtlife
wait so i could just take the whole rear assy?
so then a scion really is just a yaris with a toaster body
Old 01-20-2023, 10:54 PM   #6
Compeer
Yeah just checked XB has the same arm by the looks c
Will need to double check that I could not find the vitz rs part number.
Old 01-21-2023, 10:56 PM   #7
remcafee
i will stop you right there, im 99.9% sure scion xas are rear drums
Old 01-22-2023, 01:44 AM   #8
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I'm 100% sure.
Old 01-24-2023, 05:26 PM   #9
Neinris
Drives: 08 Yaris 3 Door Hatchback
The 2nd gen xB has rear disc, also 5 lugs 5X114.3. Still trying to find out if rear axle frame will fit the Yaris...
Neinris is offline   Reply With Quote
Old 01-25-2023, 08:57 PM   #10
sh0rtlife
welp the deal for the gen1 fell thru...ive got 2 others im working deals on..another gen1 and a gen2......if the gen2 happens ill be able to figure it out in short order..but me and my wife both LOVE the lil gen1 toasters...and have always wanted one
Old 02-01-2023, 12:48 PM   #11
sh0rtlife
i keep coming across totaled but running XB's second gen, annd it begs the question...why hasnt anyone used one as parts to do a 2.4 swap into a yaris?!?!?!?
Old 02-03-2023, 10:01 PM   #12
Neinris
The 2ZR from an xD is more of a straight swap. I've thought about dropping in a 2AR in my Yaris, it's heavier though. You might want to grab the engine and transmission from a tC instead.
This guy was able to squeeze out 270HP out of a 2AR and he's installed it in his MR-S, he's also put a 1GR and 2GR in his MR-S:
https://www.youtube.com/@FrankensteinMotorworks
Old 02-04-2023, 07:21 PM   #13
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
a 2AR-FE in a Yaris would make it brutally front heavy, also FrankensteinMotorworks is an encyclopedia on MR2s, GR and AR engines. Super knowledgeable dude.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
engine swap complete..thanks to all flathead6 DIY / Maintenance / Service 4 05-12-2019 07:12 PM
