2008 Yaris Roof Strips
I have a stupid question. Are the black strips on either side of the roof a part that can be replaced or is it some kind of sealant. The strips on my 2008 HB are coming loose and I don't know what to replace them with.
Thanks! Roger |
Funny that you would ask about these right now. It's about that time, isn't it? I just got an email this morning about replacement strips for my '07 having shipped. I have a contact at Claremont Toyota that told me these on eBay are the exact same thing, but a little cheaper than going through the dealership. Apparently, they pop off and back on with some clips that are underneath.
Hope it helps! |
![]() Drives: 08 Yaris 3dr Join Date: Oct 2018
The roof strip has a clip at the front and a clip at the back. The rest of it just pushes into the track.
Thanks for the info!
The left side on my '08 is coming a bit loose on the left side. I wonder if the rubber just stretched over time or what. lol
![]() Drives: 09 Yaris 3dr Hatchback Join Date: Mar 2015
Yes, that is the correct part. I just replaced mine in February.
I made the mistake of ordering through the dealership ![]() I also made the mistake of ordering the clips. There's no need to order them. The moulding simply snaps on to the existing clips. Don't be like me. Save your money |
Mine are doing the same. But also probably cuz i removed them to paint the roof. Now i know im not the only one
#8 | |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
I'm a hermit named Lee |
#9 | |||
My pleasure!
![]() ![]() Drives: 08 Yaris S Sedan AT Black Join Date: Oct 2008
I need to replace mine also, can anyone post a video or pictures of how it is done? I understand that there are 2 clips, from which direction do they clip? I need to remove the old ones but don't want to break the clips and haven't found any pictures to give me confidence.
Cheers. |
#11 | |
While I don't have pictures, replacing the roof strips is very easy. I would recommend getting something under the strip near the middle of the vehicle to pop the strip out of the track. Maybe a pick, or a thin screwdriver wrapped in a cloth. That should give you a good view of the clips. One at the front, and one at the back that should help you figure out how to the the strips off the clips. In my experience, it didn't take much in order to get the strip off of the clips. Don't force it, and the clips shouldn't break. |
There's a clip on the roof of the car at each end of the track that the molding goes into. The molding slides over those clips at the ends and then just snaps in and fits snugly throughout the middle section.
I remember starting at the rear point of the molding, by the hatch, and pushing it forward toward the front of the car. That creates some slack that you can use to free up the front clip near the windshield and then free up the whole thing. It's really easy and you'll see that once you get into it. I didn't do any research prior but just pushing on it a little from the back revealed everything I needed to know. |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
Apologies for the revival, but I just want to share where I got mine. I found a pair for really cheap. I just got done installing them, and they fit really well. They do stretch out, but I compressed them to the perfect length of the roof. Hopefully they last long. I just don't know which end is the front, because I've removed my old trim and discarded them about a month before the install. I decided to install the tapered end at the back, for the water to exits easier. The front of the roof, along the windshield, is fairly flat, so I thought that the flat end should shouldered up with the roof. Am I wrong?
https://www.ebay.com/itm/195489194422 |
One of my strips came off at one end when the clip broke. I just glued the end of the srtip in place with clear silicone calk and it has held for over a year now. ....just cheap fix but it works.
![]() Drives: 2008 Yaris white Join Date: Dec 2009
Black strips on roof of 08
My black strip on the passenger side has been loose for a while, I put black tape on it and some tape on the other side. I wonder if that is where the leak is coming from. Water is getting into the trunk and cabin. I put tape behind the passenger's side back break light. I took out the plug-out trunk to get water to drain out the water and I wonder if other plugs are clogged. But yeah strip has been bad on my 08 for years. I had to be careful when going thru the car wash, it would pull that strip almost off.
![]() ![]() Drives: . Join Date: Mar 2019
My strips are gone.
Do they have any other use besides aesthetics? And why DOES the roof have 2 gullies in it? |
![]() Drives: 2007 Toyota Yaris Join Date: Feb 2023
I got these cheap rubber ones on ebay. They came rolled up and did not fit well at first. I left them out in the sun then they fit better.
https://www.ebay.com/itm/155062710999 |
| New-to-me 2008 Yaris 3 door MT | mittra | New YARIS Purchase Forum | 5 | 02-27-2015 03:21 PM |
| Quick Question about the 2008 Yaris: | doog | DIY / Maintenance / Service | 5 | 11-29-2014 12:26 PM |
| Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris | omendt | Items for Sale by private party | 0 | 07-13-2010 09:46 AM |
