![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
A/C condenser
Anybody know if there is a DIY on replacing the A/C condenser? or past experience doing that repair.
A/C
if you remove the front bumper you'll notice a cross bar above the radiator/condenser. This bar is held down by 4 bolts (2 on each side). Remove those bolts and lift the cross bar out. Once you disconnect any hoses and fitting attached to the rad and condenser you can then just lift the rad/condenser assembly out as it just sits on rubber dampeners.
The rad and condenser are just connected with clips. Unclip those and they should separate. Do the opposite to re install then pull a vacuum on your a/c system to make sure there are no leaks. Then add 1/4 ounce of uv dye and re charge your ac with just over 12 ounces of r134a. It's not a big job and once you remove the bumper you'll see what I mean about the cross bar. The hood latch is held onto it with 3 10mm bolts so you'll have to remove that as well.
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Here's the procedure from the factory service manual.
A/C
| Help: A/C Questions | flamingchicken4 | DIY / Maintenance / Service | 11 | 12-29-2018 01:53 PM |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 05:00 PM |
| Larger condenser for stock A/C? | rningonfumes | DIY / Maintenance / Service | 3 | 07-25-2016 10:43 PM |
| Replaced my A/C condenser | villdemar | DIY / Maintenance / Service | 5 | 05-28-2016 03:13 PM |
| Just replaced my A/C condenser, now what? | Astroman | DIY / Maintenance / Service | 5 | 04-02-2014 06:26 PM |
