![]() ![]() Drives: White Yaris Sedan Join Date: Mar 2014
Should I buy new wheels as well?
I have a '07 Yaris Sedan, at least one of my wheels has a small bent, which may let out some air but it's not too significant. If I did decide to buy wheels than should I upgrade to a bigger size like 16/17?
My car has about 170,000+ miles. My tires are going on 9 years old so it's definitely time for new tires but deciding on wheels. It's nice to have nice wheels for once if it doesn't cost too much more. From TireRack EDR9 Bright Silver Paint TOYO EXTENSA HP II Thank you Last edited by MoneyT8; 01-16-2023 at 02:11 PM. |
tires over 5 years old are actualy no longer DOT compliant, and in many cases no longer safe ...atleast at higher speeds
as far as a size change goes, idealy you need to stay "light" and only go as big as you have to personaly i wouldnt put on anything bigger than a 15, and actualy prefer my 14's with a 195 60 14 if you bent a wheel.....then that tells me you drive on questionable roads and need all the sidewall you can get to protect the wheels from getting bent, which means 14's |
#3 | |
I currently have 15' and will probably stick to that if I don't choose to go bigger. My area is ok, bought this car used so who knows where it was before. Also what does 38mm vs 45mm offset mean on wheels? |
thats all about how much the "centerline" of the wheel is pushed or pulled off center IE deep dish vs shallow
not knowing what tires your running i would however reccomend going to a 195 or 205 in width...makes the car a whole lot more grippy in the corners and less slippy in the wet and a lil extra width wont toss on any weight |
#5 | |
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
imo anything wider than a 195 on these cars....unless youve got some serious engine mods...is right on the edge of the most tire it can physically use, its neerly un spinable if you get a sticky one..but even a budget cheepo will not spin in the dry
as far as 16 17 and up..your just adding un needed weight in the WORST possible place to add weight to a car with 100hp....if you really have to go big for your own aesthetics make sure its an ultralight wheel |
I always ran 205/50/16's on lightweight wheels on stock suspension on both my Yaris. I think it was the ideal set-up for great handling and appearance. Don't run an aggressive tread if you want good straight-line tracking at high speeds with this little car. Look for a continuous centre rib tread design.
#8 | |
Those wheels do look fire tho. |
#9 | |
13, 14, 15, 16, 17..makes no differance on "gear ratio" and neither does 175, 185, 195, 205 etc its all about the middle number IE 195/"60"/14..60% of the width"195" is the total height of the tire..thats why the middle number is called the aspect ratio 195/60/14=23.2 175/70/14=23.6 225/45/15=23......way wide but still the same ratio 195/55/15=23.4 295/35/15.....10 inches wide but still the right height for the ratio LOL 205/45/16=23.3 196/40/17=23.1 i could go on and on... https://tiresize.com/calculator/ |
#10 | |
I never said the width changes the gear ratio. My cars speedo sensor was tuned for 17" factory allows and with my current 15's the speedo is reading just under the correct speed which means I have lowered the final drive ratio of the gearbox. At 100kph on the speedo the roadside speed display signs show me at 94-96kph. 17" made the car feel even more gutless down low and a little more floaty feeling. https://www.onallcylinders.com/2015/...l-drive-ratio/ |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
Personally I use this calculator instead:
https://www.wheel-size.com/calc/ Not only does it show the tire size, it also shows necessary offset. What I didn't see mentioned are the supposed stock wheel/tire sizes of 175/65/R14 = 23 and 185/60R15 = 23.7 I discovered that there are two different speed sensor gears, mine has the one for 175/65/14, so my 185/60R15 tires makes my car go faster than what's indicated on the gauge cluster. Use the calculator provided to get to the closest stock tire size. If you want to get better gas mileage, get a bigger diameter wheel/tire combo. For acceleration, smaller diameter. |
#12 | |
the center rib is a good call generaly, i dont think my quatrac5's have it but good god are they sticky...wet, dry..amazing stuff and neerly as good as a set of blizzaks in freezing rain ice packs
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Finding 16" performance tires under 24 inches is a pain. Took me quite a while to find a tire shop that could get me BFGoodrich Comp-2s in 205/45/R16. I'd consider going to 15s if I could find a set of 15x7 Enkei RP01/02s with +35mm offset. I currently have 16x7 +40 RP02s and love them.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
#15 | |
Gen 3 > Gen 2
Very hard to find, Tirerack only sells 3 different tires in that size. Or else I would prefer 215/45/16
#17 | |
Yes very limited, but I found 5 in my zip code. Maybe try a different zip code? |
What do you guys think about Goodyear Assurance All-Season Tires? Thinking about getting goodyear but I've read a lot of horror stories on goodyear tires in the past so hopefully this time around, they have improved.
