![]() Drives: Yaris 1.0L Join Date: Mar 2011
Dashboard Clock goes off?
Hi,
When I started the car this morning,the clock and BC indicator suddenly goes off.Anyone has idea what it could be?? |
![]() ![]() Drives: 2010 5spd sedan Join Date: Nov 2012
Try the knob to the left off the steering wheel, turn it til it clicks
What knob?There is only for the mirrors and headlights
It's the like a spinny switch that adjusts the dimness of the gauge cluster, i believe it's right under the cup holder. I accidentally hit it one time and the clock light would go off when i turned on the headlights, i thought something was wrong. It took me taking it to autozone and a little experimenting.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Most of the European ones do not have a dimmer rheostat like our US ones do.
What year is the Yaris? And, does it have the digital or analog instrument cluster?
The Year is 2006,and the cluster is digital.
OK - So definitely no dimmer rheostat.
Check the 7.5A MET, 7.5A PANEL1, and 7.5A PANEL2 fuses all of which are in the fuse panel that is under the bottom of the dashboard.
That is left under from the steering wheel,when I remove the panel,right?
Yes - If your car is left hand drive it is to the left of the steering wheel and and it is under the bottom of the dash, so you look up from the floor to see the cover, which has the labels.
Ok Scott,
I have checked the fuses,they are Ok.I disassembled the cluster,and there where no bulbs.What now? |
What parts of the instrument cluster are still working properly?
Everything works as it should be,only this right corner,where the clock,trip computer and the MPG shows,that part is out of light.When I took apart the cluster,I notice that this particulary part containes small LCD display which is attached to this connector.And behind that is small circuit board that controls it.I did not see any bulbs.Maybe it is an electrical failure,or something like that.
#13 | |
#14 |
I have both owner's and repair manual,and I can't see nowhere that problem.
Altought I've downloaded the owner's manual,and it's only for US and Canada models.European couldn't find nowhere.I need it exactly for digital cluster,anything else is useless. |
#15 |
I have parts of the European service manual, but it does not indicate being able to turn off the clock. Sometimes the owners manual has some additional information on those kinds of "features".
#16 | |
Any answer is a welcome. |
#17 |
Other than one of the connectors having been loose, I can't think of anything else that you can easily check. At this point, if you can find someone with another Yaris with a digital cluster, you could try swapping the two to verify that the problem is with the actual cluster.
#18 | |
We don't have much Yaris in my town,so the second option falls thru. By the way,I forgot to tell you,there is a smaller connector that connects speedo gauge with the hausing,or something like that.Anyway I will try to do something.Thank's again. |
Thread Tools | |
Display Modes | |
GI: "YarGauge" replacement clock module (Digital Tach, etc.) | CTScott | Items for Sale by private party | 756 | 03-21-2013 08:22 PM |
05 Echo changing time on clock | jambo101 | DIY / Maintenance / Service | 3 | 11-12-2011 04:34 AM |
Dashboard mount for iPhone 4S? | shima | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-25-2011 09:22 AM |
Dashboard remove ... ALL of it | Toji | Cosmetic Modifications (Exterior/Interior) | 7 | 02-26-2011 06:30 AM |
Setting the clock after DST change | ToddR | DIY / Maintenance / Service | 10 | 03-09-2009 11:33 PM |
