Old 04-01-2024, 01:48 AM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
1nz-fe ported intake manifold and 2zr-fe throttle body+ Trust Filter/adaptor
I have been at it again and have spent the last week porting out my shorter rs intake manifold and then fitted this new to me Trust airfilter/adaptor combo. It uses my custom brass intake tube with the old tube cut and wrapped around it for insulation and a little bracket i made up, Sounds really good now.
Hand ported to 58mm at lip 54mm smallest, Epoxied the holes it made and added the square at the top so we have two sealing edges.
Checking porting job with my spare throttle body.
Manifold ported, next step was to make a new gasket, used thick cardboard I soaked in oil.
Decided to tidy up the outside with a quick paint job.
Facebook marketplace gods blessed me with this Trust airfilter/adaptor combo right as I finished my porting Came with a new foam insert too
Next up I made this mounting bracket from some alloy bar I had, it bolts directly to the airfilter and then down to the factory air box mount
All installed.
Little video of some dooorts!
https://streamable.com/8n2nmx
Car sounds amazing and really seems to rev out much faster now! Really happy with it! Also join the discord for original posts! https://discord.gg/DFZhWKMSbf
Compeer is offline   Reply With Quote
Old 04-05-2024, 09:45 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
2ZR throttle body works too? That's wild.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 04-07-2024, 07:10 AM   #3
Compeer
Yeah man works mint once you tune the idle throttle position to 15%
Old 04-07-2024, 09:58 PM   #4
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
No need to swap the chip or any of that nonsense?
2014 NCP131 5 Speed
Old 04-08-2024, 02:42 AM   #5
Compeer
you always have to swap the chip.
Tags
1nz-fe, airinx, trust, vitz rs, yaris
2zr throttle body tmontague Performance Modifications 1 10-07-2018 09:21 PM
1zz-fe intake manifold on 2zr? deadcrow Yaris TS Talk 1 04-05-2012 05:51 PM
