Old 11-12-2008, 12:58 PM   #1
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
Squeaky Transmission? 5MT
I have a strange occurrence where my Transmission squeaks just the slightest little bit when going into and out of gear...mostly 3rd and 4th. I originally thought it was my brakes or someone elses brakes. It doesn't happen every time though either. Can anyone tell me what is going on?
Old 11-12-2008, 02:01 PM   #2
kou
Drives: 08 lb
lube this part. if you look under the hood at your linkage move this part side to side and lube. white lithium grease in the spray can works great.
Old 11-23-2009, 08:57 PM   #3
Henry G.
Drives: 2008 Yaris HB
Props to KOU big time. I havent got the lithium grease in a spray can yet but just squirting some WD-40 where you showed in your pics made the squeek disappear and noticably easier shifting instantly!! I sprayed there and every adjacent pivot point I could reach and the result was immediate. Actually more difference that changing to MT-90 for shifts per se. Thanks bud!
Henry G. is offline   Reply With Quote
Old 07-30-2012, 07:53 PM   #4
hjsya
Drives: 07 Hatch
Many thanks. Searched online for a cure, found this post and joined the forum. Lubed the linkage joint with dri slide (motorcycle stuff) and the squeak is gone.
hjsya is offline   Reply With Quote
Old 07-25-2013, 05:32 PM   #5
ckurowic
Drives: 2007 LB
Thumbs up
EPIC. Thanks for this, I'll try it this weekend on my '07.
ckurowic is offline   Reply With Quote
Old 07-07-2021, 08:56 AM   #6
07Yaris94
Drives: Yaris SR 2007
Guys, I'm convinced this is my issue, but I cannot for the life of me find this part. I have an 07 Yaris (UK). Can someone show me where I'll find this in my engine bay?
07Yaris94 is offline   Reply With Quote
Old 11-12-2008, 03:16 PM   #7
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Thanks kou! I've learned to live with the squeak but hopefully this DIY will kill it. Any brand recommendation for a "white lithium grease in the spray can"?
aca72 is offline   Reply With Quote
Old 11-12-2008, 03:21 PM   #8
kou
Drives: 08 lb
no special brand its just easier with the can,it should come with a little red straw for the nozzle. spray in the gap between the two parts.it moves side to side when going 3-4.i changed the pic slightly so you can see where to spray exactly.
Old 11-12-2008, 03:46 PM   #9
slothman86
slothman86's Avatar
Wow, so the yellow part? and the squeak will be gone?
Old 11-12-2008, 03:48 PM   #10
kou
Drives: 08 lb
spray in the two little yellow marks inside the circle and the noise should go away.
Old 11-12-2008, 04:31 PM   #11
slothman86
slothman86's Avatar
thanks much! I appreciate it!
Old 11-12-2008, 04:35 PM   #12
kou
Drives: 08 lb
anytime.
Old 11-12-2008, 08:11 PM   #13
ruimond
Drives: Yaris YR
Haha i had this problem, i actually got it fixed this morning too by the Toyota Service Mechanic, he sprayed some stuff on that part to. Now it's gone. :D
Old 11-12-2008, 10:42 PM   #14
slothman86
slothman86's Avatar
I went ahead and bought some of the before mentioned lube from advance auto for about $3. I sprayed some on each linkage just to make sure. There is no squeak anymore. You may need to take out the air box and battery tray to be able to lube everything up...unless you are Mr. Fantastic. ^^ Great advice! I may spray this on some suspension bushings as well...
Old 11-13-2008, 01:07 AM   #15
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Thanks for the post... this has been squeaking on mine for the last couple months. F the dealership... I'll do it!
2006 Red Blitzed RS 5-door
Old 11-13-2008, 08:59 AM   #16
IllusionX
Drives: 07 Yaris Sedan Aero
haha.. mine is doing that since 2+ years ago... and is still doing it after 53000km. ^^
my personal toyota mechanic told me to take the shift linkage out and grease the hell out of it. but i got lazy and never did it. haha but thanks, i'll shoot some grease to that part see how it goes.
Old 11-13-2008, 12:11 PM   #17
TheSilkySmooth
TheSilkySmooth's Avatar
Now i see where the battery GND is!
You may wanna to try a dry moly lube so you don't collect any sand if you live in areas where the roads are sanded
Sonja's Bro
Old 06-25-2009, 09:15 AM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
it's the one with the big + next to it, right?
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
