Old 04-18-2009, 09:06 AM   #1
1nz
Drives: Vios
Trouble Code P2121
I had this problem twice today:
when this happens CEL comes on and p
ress the throttle 100% and it only opens 15%
1st i reseted the battery, after 20-40km or so light turns on again at traffic light and my car cant move, when i checked the rpm engine is idling even when i pressed the pedal, hold my feet on the pedal and suddenlyu car move and again full pedal = 15% throttle luckily this time i try clearing the trouble code using my Greedy informeter and car is back to normal.
When i checkd the trouble code it chouws P2121 which i cant seem to find in the toyota nation website
anyone have any idea?
Please visit us @:
greddyvios.blogspot.com
1nz is offline   Reply With Quote
Old 04-18-2009, 09:42 AM   #2
1nz
Drives: Vios
Originally Posted by camelll View Post
this is for the 1gr-fe and I assume it would be similar.
http://www.purefjcruiser.com/docs/20...em/0050054.pdf
Thanks.... thats the one
This one is the closest related issue, but if that was the problem, i would appear again when i clear it when i was driving right? luckily with this informeter can clear it without removing the battery terminal
Please visit us @:
Old 04-18-2009, 10:22 AM   #3
1nz
Drives: Vios
i'l just check the connection tomorrow if it appears again i'l definitely send it to the shop, and maybe it's also caused by my emanage harness bad connection maybe hehe will check it out
Please visit us @:
Old 04-18-2009, 12:18 PM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I had the P2121 a few weeks ago when returning from a long trip and did the last 200kms with the engine light on and the gas pedal feeling strange on acceleration but it would cruise at highway speeds.Next day i openened this post http://www.yarisworld.com/forums/showthread.php?t=15801
To discover it was throttle position sensor related however when next i started the car some 24hrs later the problem has gone away and hasnt been back since.
Old 04-18-2009, 02:42 PM   #5
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
I'll take a guess that you sprung a vacuum leak somewhere (intake manifold?)
In any case, take it to the dealer. Might even still be covered under warranty.
Old 04-18-2009, 11:05 PM   #6
1nz
Drives: Vios
Problem is as soon as they see my emanage plug n play harness they will void my warranty and if i send it there theres a posibility the problem wont appear so if it appears again i will send it there
Please visit us @:
Old 05-28-2011, 03:28 PM   #7
DAEL
Drives: 4 DR YARIS SEDAN
I took off my connections, contact cleaned them (spray) then used silicon dielecrtic paste. these are old messages. Nothing recurring?
DAEL is offline   Reply With Quote
Old 05-17-2022, 04:57 PM   #8
kunitt96
Drives: vitz turbo
i have the same problem.
do you fix your problem?
Or does anyone have any information?
i remplace my tps and my pedal :( :(
regards
kunitt96 is offline   Reply With Quote
Old 09-02-2024, 08:58 AM   #9
rayfloyd170
Drives: Yaris 2016 1.3 Manual
My friend's 2009 Yaris Manual has a persistent trouble code P2121 with a weird gas pedal behavior. He has to step gas pedal 2-3 times before it starts to accelerate which is very unsafe. If he is in uphill condition with cars behind him, he could easily hit them if the gas pedal won't respond quickly.
I took off and dismantle the accelerator pedal assembly with integrated hall effect sensor. the magnet was intact as well as other things. Found a lot of debris and dirt inside. Only (2) 10mm bolts were holding the pedal and 4 torx screws. I just grabbed a contact cleaner and gently sprayed it, removing the dusty particles. The green plastic - shoulder sleeve bushings that act as a bearing are partially worn out. I believe the dust particles inside the pedal assembly were from the bushing material and the plastic pedal mechanism rubbing each other creating menace to the hall effect sensor. I cannot find a replacement online for this bushing/bearing which is probably Teflon-coated (green color) so I just cleaned this part and dub it with silicon oil due to some of its surfaces were scratched and lost its self-lubricating effect.
I cleared the persistent P2121 error, and it never comes back after. The gas pedal is also now very responsive.
Will post pictures later.
rayfloyd170 is offline   Reply With Quote
Old 09-02-2024, 08:59 AM   #10
rayfloyd170
regards
@kunitt96
just open the pedal accelerator and clean it with contact cleaner and install back. most likely has dust and particles inside which affect the hall effect sensor
Code P2121 jambo101 DIY / Maintenance / Service 5 07-21-2011 02:40 PM
Doh! My Bad (Throwing a Code) Treyz General Yaris / Vitz Discussion 8 11-25-2008 11:07 AM
P0456 OBD code? jlift DIY / Maintenance / Service 6 09-19-2007 04:28 PM
YarisGarage trouble? ChinoCharles Suggestions - Feedback - Questions 7 08-16-2007 05:48 AM
Having Trouble with TWM Short Shift Install. Need Help xfatefailsx07 Performance Modifications 3 10-10-2006 02:38 AM
