DIY - Exterior lights on when doors are remotely unlocked
The dome light on the Yaris comes on when the doors are unlocked, so using a relay one can drive the headlights, parking lights or fog lights from the dome light feed, so that they illuminate when remotely unlocking the car.
Note that since the dome also comes on when simply opening the door, the exterior lights connected using this DIY will come on when opening the doors as well. Materials required: 1. Automotive type relay 2. Relay socket or 5x 1/4" female spade terminals (and wire) 3. 4x 24-18 AWG tap splices 4. 1x 1/4" ring terminal In the picture below, the top relay is shown with a relay socket and the bottom relay is shown with 1/4" female spade terminals. Relays.jpg The terminals on a "standard" automotive relay are labeled as 85, 86, 87, 87A, and 30. For 2006-2011 Yaris: ![]() Relay pin 85: Connect to Light Blue wire on dome light connector (in the first picture) Relay pin 86: Connect to Pink wire on dome light connector (in the first picture) Headlights on when unlocking: Relay pin 30: Connect to the light blue wire, next to the pink wire Relay pin 87: Connect to the white/black wire, next to the light blue wire Parking lights on when unlocking: Relay pin 30: Connect to the white wire in position 13 (in the second picture) Relay pin 87: Connect to the wire three wires over to the right from the position 13 wire. It will either be white/black or green. Fog Lights on when unlocking: Relay pin 30: Connect to chassis ground (easiest way is using a ring terminal installed under a bolt that goes into the metal of the dashboard support frame). Relay pin 87: Connect to the Yellow wire on the headlight switch connector. (in the second picture) For 2012-2013 Yaris: This is the body ECU, under the left side of the dash. The connector on the top right is D143. The connector on the top left is 3D and the one of the bottom right is 3C. Connectors 3A and 3B are on the back side of that white plastic box. ![]() ![]() ![]() ![]() ![]() This is the headlight switch connector (D106): ![]() ![]() Relay pin 85: Connect to Sky Blue wire in pin 5 of connector 3A Relay pin 86: Connect to Black wire in pin 6 of connector 3B Headlights on when unlocking: Relay pin 30: Connect to the wire in pin 20 of the headlight switch connector (in the picture above it is the green wire on the top right, but the color can be green black or light blue) Relay pin 87: Connect to the white/black wire in pin 12 of the headlight switch connector (in the picture above it is to the right of the red wire) Parking lights on when unlocking: Relay pin 30: Connect to the sky blue wire in pin 18 of the headlight switch connector (in the picture above it is to the left of the green wire on the top right) Relay pin 87: Connect to the white/black wire in pin 12 of the headlight switch connector (in the picture above it is to the right of the red wire) On the 2012-2013, the fog light wiring is not accessible to allow them to be wired to be on with the ignition off.
2ZR swap. DO IT! Ask how!
I'm not sure where you find the time for this stuff, but it's great to have!
The first attachment seems to be broken though... |
Fixed - Thanks.
![]() Drives: Yaris 1.0L Join Date: Mar 2011
Great!!!
But I'm not sure is that the same wire colour for the parking lights on the second picture with the european models. |
You are correct - The European Yaris does have some different colors for some of the wiring.
Can you find out which colour is for the parking lights,cause I want to switch it from headlights.
For your European Yaris, it will actually be the same as for the US Yaris. I had a typo in that section for the 2006-2011, which is now fixed.
Just out of curiosity and looking into the future (IDK, this may be an eye roller of a question re lameness --- I don't have power locks nor keyless entry on my Yaris), would the setting on the dome light have any effect on the lights controlled by this DIY? In other words, would setting the dome light to off (one of the 3 settings on the 1st gen USDM Yaris) keep the dome light (and the lights related to it re the DIY) off when utilizing the keyless entry?
#9 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Scott, if I were in CT and you were a lady, i wouldve kissed you for this. LOL
Seriously, great writeup! i'm so doing this. :) T H A N K Y O U :D curious question though, (since im doing the parklights), this shouldnt cause any issues with the way the parklights work right now or anything else for that matter, should it? thanks again. |
#12 | |
always toyin'
This is like asking Chef Ramsay if he knows how to prepare a Risotto ...
- Procrastinators of the world unite! ...tomorrow. ![]() My Garage.. 'Mild' Drop & Misc..2-DIN GPS/Navi..DIY:Rear Wiper Delay..Ramps/Roll-Ups..Rain Sensing Wipers / Auto-Headlamps |
Correction scott, you got a typo.
For parklights pins 13 and 10 should be relay 30 and 87,respectively. |
Inversely, what would one have to do in order to have the headlights turn off when the car is locked?
#16 | |
My headlights off with the ignition DIY is the easiest way to get close to that: http://www.yarisworld.com/forums/showthread.php?t=14427
Drives: Toyota 86 GTS Join Date: Dec 2013
wow
Hi CTscot
I really like your post. Could you help me do the same thing but with a Toyota 86? Here is the wiring diagram http://www.ft86club.com/files/BRZwiringi.pdf I had a look at the Yaris diagram and it is similar but would really like some help. Thank you! |
#18 | |
You could try grounding the white wire in pin 20 of the headlight switch. If that works for making the headlights come on with the car off, then you would connect one contact terminal (30) of the relay to that wire and the other (87) to ground. You would then connect pin 17 of body ECU connector D5 to the relay coil terminal 85 and terminal 86 of the relay coil to the dome light positive wire (it doesn't look like there is a simple connector for grabbing that wire, so you would have to find one of the orange or light green wires on page 184/185.)
| Car doors are not self-locking when left unlocked | fainty_girl | General Yaris / Vitz Discussion | 27 | 03-14-2011 10:12 AM |
