Old 08-23-2025, 06:51 PM   #1
LarsoyH
Drives: Toyota Yaris
ABS problem 05 Yaris
Hello!
I have a french built Yaris 1.0 2005.
Problem is the ABS light is on.
When I short pin 4 and 13 as per the troubleshooting guide I get code 3-2 flashing. I also tried clearing the coedes and it comes back right away.
I replaced the left front ABS sensor thinking it would solve the problem, but unfortunently it did not.
So I figured the tone ring might be broken, but then I read the abs do not use standard tone rings, and instead use some magnetic strip inside of the bearing?
Could this magnetic strip be damaged in any way, which would warrant a replacement of the whole bearing?
I have no noises from it and it is working just fine as for the bearing funtion, so I would rather not replace it if possible.
Any other leads which might give code 3-2 except the ABS sensor?
I need to fix the ABS for my car to pass road inspection unfortunently.
LarsoyH is offline   Reply With Quote
Yaris 2004: ABS issue YarisPie DIY / Maintenance / Service 1 06-13-2025 04:21 AM
ABS, BRAKE, Harness Troubleshooting Diagnostic Guide XP90 2nd gen IndestructibleYaris DIY / Maintenance / Service 0 09-05-2024 06:19 PM
New Yaris Gearbox Problem..... petesimla New YARIS Purchase Forum 22 04-10-2019 09:04 AM
acceleration problem yaris 2012 sedan ahmedmhb Middle East 1 10-17-2013 05:32 AM
