Vitz_RS
Drives: Toyota Vitz RS NCP91 Join Date: May 2009
Hello..
i need an urgent help guys ... I have my car ECU damage and my car if from Japan. Have anybody replace their ECU with one coming from UK or US. My ECU is 89661-52b10, whereas in UK or US it is 89661-52E90 (different) Can it be re-program for the key? I have a Toyota Yaris Year Feb 2006, NCP91 Thanks for helps! |
The ECMs are specific to the engine type and to the key security system (transponder key, smart entry, etc.). Which engine and key security does your 06 have?
Vitz_RS
I have engine start with wireless key...do you think the ecu is programmable
No - The ECM is definitely not programmable. You will have to find an ECM with the same part number as your current one.
Vitz_RS
wow.. that the most difficult to get, any idea about Standalone ECU
Thanks for help |
#7 | |
A standalone would handle the fuel, ignition, etc. aspects of running the engine, but won't handle all of the other functionality of the ECM. What exactly is you ECM doing or not doing?
Vitz_RS
MY OEM ECM is damage, i need to replace it and all work also the keyless entry
Vitz_RS
Mine is a 89661-52b10
#11 | |
The reason I ask is that I have spent enough time inside of the ECM that I may be able to repair it, depending on what happened to it.
Vitz_RS
Yeps..I'm not getting power on the third ignition and spark plugs which result low in torque..the wiring was check OK, they suspect the chip for mapping is damage
#13 | |
If it is definitely the ECM that is not outputting to that coil pack, it may be a fairly easy repair to replace the driver for that ignition output (which is a transistor).
#14 |
Vitz_RS
Where is the coil packs please...the transistor has been check and inverse also still the power not coming in the third line ignition
#15 |
The coil pack is the part on top of the spark plug. The transistor has probably not been checked, since that is a part on the circuit board inside of the ECM.
#16 |
In event of the main ecu replacement, is there anything to do like programming or replace other ecu(transponder, abs etc.)
Is it a direct bolt on with same part number? I am reading the service manual and observed that it needs only to program the VIN which is optional I guess.. CTScott, any thoughts on this? |
#17 | |
Because he has the smart entry system, that system will need to be resynced with the new ECM (which requires the techstream tool to do).
#18 |
Vitz_RS
Here in Mauritius their is little expertise to check or repair the ECU, that's why i am looking for an ECU with the Key less key include for replacement
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Connects2 UNI-IR Universal Infrared Steering Wheel Control Interface | rognewton | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 05-04-2011 09:42 AM |
| 3 Drive Throttle Contoller by NTD | Sabretooth | Performance Modifications | 31 | 10-07-2010 12:12 PM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
