Chode
Drives: Silver 5 Door YRX 1.5L I4 Join Date: Feb 2007
DIY Tacho install question
i have a RHD yaris and i was wondering if the installation for a tach is the same? just on the other side? (ps i know all australian yaris' have a tacho already, i just dont like digital)
I also attached photos to show what is on the other side (whats in the white plastic casing? and is that the ecu next to it?) |
Chode
oh, i forgot to mention, I have the safety pack which includes the drivers knee airbag. is that where it is? behind it? is it safe to try and remove it?
Chode
on page ST-38 to ST-39 (STARTING) in the service manual, the fuses are in the same place despite the side of the steering wheel.
vasilios: do you think i should buy a cheap diagnostics cable and just wire it up to that? id rather do it than get blasted by the airbag |
Chode
the diagnostics port is under the steering wheel, but removing the airbag cover/the airbag itself would make it much easier to work on. Anyway i read the SRS part of the manual and it says it has a backup battery which lasts 90 seconds after the battery is disconnected.
I think the yaris is build pretty much the same round the world, because the fuses and relays (like in my first post) are in the same place as the overseas models. (+/- features included/not included) Something else that pisses me off is that we cant even get a factory cruise control, climate control and that my radio doesn't have MP3 input. (6 stacker, looks different to everyone elses) and that the shit model does. |
white thing is your blower motor and condensor for a/c unit. also on upper part of this unit is where your pollen filter goes. next to that is your fuse relay box. the big black wire comes in directly from your under hood fuse box (which is 12v direct from the battery. it is constantly hot so there is always 12v whether the car is on or not. do not splice this wire or the tach will run all day with the car off)
i used a piggy back fuse and ran voltage off of the guage cluster fuse and audio fuse. this view is exactly the same as my left side drive except for the fuse/relay box is on the left side. hope this helps
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
![]() ![]() ![]() Drives: None Join Date: Mar 2007
Chode
It could be a socket round the back of the head unit, and the input socket is supposed to be near the handbrake, (and could be the same on the GPS head unit) but i dont have the right part. I need a 3.5mm plug-to-3.5mm socket. (or something like that)
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 10:15 PM |
| Factory armrest install DIY. | PetersRedYaris | DIY / Maintenance / Service | 16 | 07-27-2012 06:25 AM |
| n00b suspension install question | The Stig | DIY / Maintenance / Service | 25 | 07-12-2007 09:58 AM |
| Sirus Radio install question | brpnagger | Cosmetic Modifications (Exterior/Interior) | 5 | 06-25-2007 10:21 AM |
| question about radio install | misfits9095 | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 06-06-2007 04:08 PM |
