Old 06-23-2006, 05:02 PM   #1
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
installed head unit...
2007 yaris sedan
ok, enough about the wife, today i installed an Alpine head unit, using the 2006 echo install kit, and toyota wire kit..
the echo kit was an AI kit, and basically the only part used was the plastic plate and bin, the mounting brakets in the kit DO NOT work, i had to mount the head unit to the stock toyota brakets.
the plastic plate fits 'sorta" will be looking for another solution when a yaris specific kit comes out.
will post a dash shot later.
punch is offline   Reply With Quote
Old 06-23-2006, 07:37 PM   #2
yarislover
BUY ONE DON'T STARE
Drives: 07yaris liftback
I used the same kit what a pain. I used the original mounting bracket,grinded off the points that stick out on the side. You need to use the mounting bracket that comes with the kit to secure the trim. I cut 75% of the plastic and screwed it to the side along with the original bracket. It looks great and is secure but a little work to make it fit perfect. I will post pics when I have everything apart to run my amp cables.
yarislover is offline   Reply With Quote
Old 06-24-2006, 10:03 AM   #3
Toddhata
Toddhata's Avatar
Drives: 07 Yaris Liftback, 00 Boxster
Send a message via AIM to Toddhata Send a message via Yahoo to Toddhata
After reading your comments on using a kit, I was thinking of buying either the Kenwood or Pioneer 1 DIN graphic equalizer. That way I could use the factory mounting bracket for both the Alpine head unit with the EQ below. Do you guys think that would be a lot easier than trying to get the kit to fit properly?
Toddhata is offline   Reply With Quote
Old 06-25-2006, 12:06 AM   #4
yarislover
BUY ONE DON'T STARE
That should work. You may have to watch for gap but all said and done it should fit. If it works out for you I would like to see some pics. I will take a pic tommorow and post it so you can see the finish. It does look good with the trim kit but if you have the EQ go with it, way nicer if it fits.
Old 06-25-2006, 05:17 AM   #5
punch
punch's Avatar
thats not going to work, you still need a trim kit...
Old 06-25-2006, 04:02 PM   #6
yarislover
BUY ONE DON'T STARE
your right you will need the trim kit unless you make a face plate
Old 06-25-2006, 04:29 PM   #7
yarislover
BUY ONE DON'T STARE
here are some pics
http://community.webshots.com/photo/...93381954mNFpIU
http://community.webshots.com/photo/...93381954WcPjrB
http://community.webshots.com/photo/...93381954lmSHUB
There are more pics of my car at
http://community.webshots.com/myphot...ecurity=QXBHmH
Old 06-26-2006, 01:52 PM   #8
Toddhata
Toddhata's Avatar
ok, thanks for the info. I have a kit, just waiting for my eq and head unit to come in. I'll post pics when it's all finished.
Old 06-26-2006, 11:09 PM   #9
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
does anyone know if changing the stock radio voids any electronic warranty?
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 06-27-2006, 12:34 AM   #10
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I installed my new deck before my first oil change, took it in and they didnt say a thing... dont know if they just didnt notice or what (cant miss the LED). I assume if you dont cut into any wires you dont have a problem.
mikeukrainetz is offline   Reply With Quote
Old 06-27-2006, 07:51 AM   #11
yarislover
BUY ONE DON'T STARE
I asked because I want to change my L.E.D.'s to blue and they said as long as there are NO stickers that say VOID IF SEAL BROKEN and that you don't cause any visable damage (you know what you are doing) then you are fine.
http://community.webshots.com/myphot... curity=QXBHmH
Old 06-28-2006, 02:11 AM   #12
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
switch powering to power Satellite receiver?
Does anyone know of an easy access point to grab 12 volt power to power my SkiFi XM receiver, Im looking for taping off the wires that power the 12 v power jack on the center console, anyone know what wires these are closer to a point that can be easily reached under the dash, or how to remove the center console so I can tape off it that way and run it back under the dash?
Thanks, Ron
N9QGS is offline   Reply With Quote
Old 06-28-2006, 02:26 PM   #13
Tankota
Prototype Tester
Drives: Yaris S-Sedan / FJ Cruiser
Can't help you yet.. I did find out that just about everything is under the drivers left side kick panel though, but I have yet to figure out which wire is which.. That's where the dealer tapped into everything for the Chapman alarm system option that I didn't want to pay $600 for. They pulled the alarm CPU but all the wirring for it taps in inside that kick panel, one of them has to be acc switched as well as a constant power. If if figure it out I'll post it.
Unless somebody has the wiring diagram with the color codes for the wires out there????
Tankota is offline   Reply With Quote
Old 06-28-2006, 04:56 PM   #14
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Just too new I would think for that to be published....
Old 06-28-2006, 05:55 PM   #15
Bones
Bones's Avatar
Drives: 07 Yaris S Type
Hey Tankota,
I posted all the wiring color, polarity,what they do and locations under Alarm Install. Just do a search
Bones is offline   Reply With Quote
Old 06-28-2006, 06:17 PM   #16
eight_heads
crimestopper has a dealer site that list every point to tap into and actually show pictures of most of them :p
'07 Yaris Liftback
Old 06-29-2006, 01:06 AM   #17
Tankota
Prototype Tester
Originally Posted by Bones
Hey Tankota,
Found it, Thanks!
Satellite Radio ToyotaTim In Car Entertainment + Electronics (audio / video / alarm) 38 03-13-2007 06:37 AM
anyone installed a computer n touch screen yet? Blenjar In Car Entertainment + Electronics (audio / video / alarm) 0 06-12-2006 11:06 AM
human head in coffee beans wushumasterku Off-topic / Other Cars / Everything else Discussions 8 04-20-2006 12:39 AM
