![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
How to watch DVD while driving (not recommended)
If I but a indash dvd and want to bypass ability to watch dvd while driving, there is a way to do this. Can anyone share the trick? Does it matter the brand I buy for this to work?
worked with mine.. i just grounded the green wire from the head unit to the chassis. (the wire which is supposed to be attached to the hand brake switch.
Pioneer has made it mostly impossible on the new units.
My kenwood works great just grounding the parking brake wire.
Different brands it is just in the way you ground it, but others you have to actually crack the cd player open and do something to the internals.
thanks guys!
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
My pioneer was different. It noticed that I left it permanantly left it on ground. So if I turn it off and back on, it wants you to open the circuit, and then close it again. So i put mine on a switch.
wa do dem
you could install a switch inplace of running it to the handbrake switch or park switch so if you get pulled over you can turn it off so the cop cant give you a ticket
#8 | |
huh?? are you serious about the wiring diagram? :)
that handbrake wire.. you simply need to put a switch on it.. so it would look like this.. headunit handbrake wire --------> switch <---- ground .. :D |
| Kenwood DDX7015 Indash DVD TV Mp3 Forsale!!! | doughrek | Items for Sale by private party | 30 | 08-23-2007 07:58 PM |
| Driving car at 75mph on position 3 :( | hans_fh | General Yaris / Vitz Discussion | 22 | 04-03-2007 05:09 PM |
| driving harsher..... | hoahmaru | General Yaris / Vitz Discussion | 7 | 04-09-2006 03:59 PM |
